Old 12-10-2010, 01:58 PM   #1
How To Replace Powered Jack
I have a 1992, 25 foot Airstream (Weighs 6000-7000 lbs.)and the powered jack may be getting to the end of its life. Please provide some information on replacing the jack:
- Types of jacks, capacity etc.
- Do all jacks have the same three bolt pattern?
- How do you install them?
- Does camper make matter?
- Suggestion on where to purchase powered jack
Thanks for your help, LCP
1992 25' Airstream Classic/Excella Trailer
Wilmington, DE
PARKS1963 is offline   Reply With Quote
Old 12-10-2010, 02:52 PM   #2
SteveH's Avatar
Common Sense , Texas
Certainly don't know a lot about jacks, but I will tell you that most all have the same bolt pattern, especially if you stay with the same weight rating. To remove, first jack up the front of the trailer, let it down on blocks or a jackstand, remove the three bolts at the top holding the jack in place, disconnect the power wire, and remove the jack. Installation is of course, the reverse. Don't be shocked at the price of a new one, as they are rather pricey. A friend of mine did recently replace his jack with one that he got for a good price at Harbour Freight, but I don't know the price, or the quality of the jack.
Do you know what is wrong with your jack? Suppose it's repairable?
Regards,
Steve
Old 12-10-2010, 04:12 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Camping World sells them.
Old 12-10-2010, 04:28 PM   #4
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
you can also try ebay. they have a lot to chose from.
i recently bought a new barker hp3000 at a good price.
it was super easy to install - really easier than removing the old jack.
note: make sure that there is full metal-to-metal contact between the new stand, the 3 bolts and the AS frame. this will ensure that the electrical system will run properly/ground properly.
also, you might have to buy some toothed washers. these are also recommended for a good contact between the jack and the frame.
good luck
az-streamer
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Donít Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Battery Powered LEDs funkill Lights - Interior & Exterior 4 08-26-2009 11:32 AM
Original Power Tongue Jack Repairable or Replace? Cos Jacks, Stabilizers, Lifting and Leveling 2 05-11-2009 10:39 AM
Portable, Battery Powered AC myboyburt Off Topic Forum 12 02-15-2008 04:20 PM
Fix or Replace Jack Nicksut Jacks, Stabilizers, Lifting and Leveling 1 09-06-2006 09:31 PM
Powered vents Roadtoaster Roof Vents, Skylights & Fans 4 05-15-2006 12:03 PM
