Old 03-18-2017, 09:27 AM   #1
VaTravelers's Avatar
2017 28' International
Virginia Beach , Virginia
How to raise my trailer
This might seem like a dumb question but to change out my 4 15 inch GYMs to 4 16 inch Michelins how do I jack up my 28' trailer? Seems I have to get it up on each side so I can change out both on a side at a time. I don't want to over stress the frame or body by improper jacking.
VaTravelers is offline   Reply With Quote
Old 03-18-2017, 09:41 AM   #2
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I always place the jack between the tires inward and under the flange , I place a 8" x 3/8 x 3" piece of flat steel on top of jack so top of bottle jack is putting the pressure on the verticle flange and not bending the horzontial flange, the steel piece spreads the force out to a larger area, both wheels will come up.
Old 03-18-2017, 10:24 AM   #3
Long Island , New York
Your owner's manual should have instructions on this. A jack point is just behind each rear tire labeled with a sticker and arrow. If you want to change only one tire at a time, you can drive a single tire on each side up on a thick block of wood, so as to suspend the other tire in the air.
"Keep It Simple, Stu."
Old 03-18-2017, 10:48 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
Drive up on leveling blocks
Since you have a dual axle AS, you don't need to jack it at all. Build a stack of leveling blocks and pull one wheel up on it. The other will lift of the ground. Change the tire, then pull the new tire up on the stack.
I have a bunch of plastic lego-type blocks. I find that a stack four-high is enough (except on unlevel ground once I needed five). When I got new tires this fall, I put a stack on each side of the trailer at the same time, so I could have two tires in the air at once.
I believe the 16 inch tires are about an inch bigger in diameter. So make sure you use enough blocks to ensure you have enough clearance to install the wheel with the taller tire.
SSquared is offline   Reply With Quote
Old 03-18-2017, 10:55 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Use the blocks as Ssquared
Old 03-18-2017, 10:57 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Says It's the safest way.
Old 03-18-2017, 11:06 PM   #7
Granbury , Texas
Serious damage can be done to the underbelly if jacks are not placed properly.
Like others have said...use blocks under the wheel in front or behind the one your removing and replacing.
cabinetmaker is offline   Reply With Quote
Old 03-19-2017, 03:20 PM   #8
jamieb1086's Avatar
2016 25' Flying Cloud
Oradell , New Jersey
Just use Trailer Aid. No messing around with multiple blocks. Amazon has it.
Jamie
2016 25' RBT Flying Cloud "Bullseye"
2016 Chevy 2500 High Country Duramax Diesel "Red Bull"
WBCCI #9026 Watchung NJ Unit
jamieb1086 is offline   Reply With Quote
Old 03-19-2017, 05:45 PM   #9
RxGuy's Avatar
2010 27' FB International
Fenton , Michigan
What he said...
RxGuy is offline   Reply With Quote
Old 03-19-2017, 06:33 PM   #10
2014 27' Flying Cloud
Stowe , Vermont
JaimieB has it right. If you have 2 axels, the Trailer Aid is a ramp that eliminates the need for a jack (that could cause major problems). 1st tire - 1. Loosen the bolts a bit while on the ground. 2. (if back tire is to be removed first) Put the Trailer Aid ramp in front of the front tire and roll forward up on the ramp. This lifts your rear tire off the ground. 3. Remove the rear tire and replace it with new tire. Put bolts on snuggly. 4. Roll backwards off the ramp 5. Fully tighten the bolts and check torque. 6. Continue similarly with the remaining tires. Check out YouTube video at:
VT Wanderer is offline   Reply With Quote
Old 03-20-2017, 06:01 PM   #11
Thanks all for the responses. I have two sets of leveling blocks that will make the task easy and safe.
Is it possible to raise trailer through lowering axle? P and Y Axles 12 02-25-2015 12:38 PM
raise trailer Rodglo Axles 2 04-08-2006 01:06 PM
Jack lowers but will not raise trailer-help! wayner1239 Jacks, Stabilizers, Lifting and Leveling 5 05-10-2005 07:00 PM
I need a raise! seaaudio Axles 14 05-21-2004 11:04 AM
Raise the toilet FrankR Sinks, Showers & Toilets 0 03-15-2002 10:57 PM
