Old 02-06-2009, 05:55 AM   #1
coffeydelsol's Avatar
1986 25' Sovereign
Ocala , Florida
How to crank the tongue jack?
Along the same lines, we have a question. How do you work the jack manually if it burns out? We just bought an older (1986) SOV and we can't see where you would attach a crank or anything. Any suggestions?
coffeydelsol is offline   Reply With Quote
Old 02-06-2009, 07:27 AM   #2
Community Organizer
Guido's Avatar
2005 22' Safari
South Chicago , Illinois
There should be a rubber plug on top of the jack. Look under the plug, there should be a spot to put a manual crank. That is where the light switch for the jack may be, too.
Fr. Guido
"We have just religion enough to make us hate, but not enough to make us love one another." Jonathan Swift
Guido is offline   Reply With Quote
Old 02-06-2009, 07:32 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Depending on the model of electric tongue jack that you have, access is slightly different. Basically, you need to remove the top of the power unit to expose the top of the driver shaft. At the top is a bolt head that can manually raise and lower the tongue foot with a long handle wrench or ratchet.
Brian
SuEllyn & Brian McCabe
Old 02-06-2009, 07:48 AM   #4
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
Should be a rubber cap on the op and that is where you insert hand crank!
shermantic is offline   Reply With Quote
Old 02-06-2009, 08:16 AM   #5
7751
Torii's Avatar
1975 25' Tradewind
Huntington Beach , California
If you have an older Atwood Jack then you will also need to remove the jack motor to access the manual mechanism.
Torii is offline   Reply With Quote
manual crank for 1964 electric tongue jack Croverlander 1960 - 1964 Overlander 15 04-09-2014 11:10 AM
How do you manually crank a Super Jack flyfisher Jacks, Stabilizers, Lifting and Leveling 7 06-20-2011 08:53 AM
Can you get a manual crank head for a power jack? JimGolden Jacks, Stabilizers, Lifting and Leveling 2 08-05-2007 05:00 PM
Tongue Jack - Which one?!? SilverToy Jacks, Stabilizers, Lifting and Leveling 6 12-13-2005 10:51 PM
Tongue jack crank problems TDOW Jacks, Stabilizers, Lifting and Leveling 3 06-10-2005 06:21 AM
