Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 06-24-2006, 05:40 PM   #1
Astro
Astro
Astro's Avatar
Profile:  2000 30' Limited
Exclamation How Much Weight Will The Tongue Hold??
I have a flat tire. I have two jacks at the correct postion behind the tires. Can I use the tongue jack to lift the trailer to change out the tire? It seems like alot of weight for my electric jack to lift. I do not want to damage it. If it is able to hold the weight I will start using this set up during storage to keep most of the weight off the tires.
Thank You,
Astro
Astro is offline   Reply With Quote
Old 06-24-2006, 07:26 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Thank You,
Astro
The best way to change out a tire on a multi-axle Airstream, is to place 2x6's in front of the tire that is not flat on the same sid the flat is on. Use the tow vehicle to pull the coach up onto the 2x6's until the flat tire is off the ground. Remove and replace the tire. Back the coach off the lumber, and drive away.
As far as storing the coach for the winter, putting some weight on the stabilizers to take some off the axles is a good idea. Just don't use them to lift the coach, as I have seen them break by doing this.
The tongue jack should be rated at least 1000 pounds, but that is straight up and down, not at an angle. When you start tilting things off center, all bets are off as far as weight ratings.
Old 06-24-2006, 10:04 PM   #3
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
The modern electric jacks are very beefy. I just installed my Equal-i-zer today and the jack had BOTH rear wheels of my Sprinter off the ground while trying to align the bars the first time. It was a lot of weight and it didn't even groan!! I was amazed to say the least!!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 06-25-2006, 07:48 AM   #4
overlander63
Rivet Masher
L.A. , California
You know, I went out and looked at my old (non-power) jack last night, and it has the weight capacity stamped on a mounting ear. In this case, it was 2500 pounds.
Sovereign weight and Preferred tow vehicle JLD 1978 Sovereign 3 03-05-2008 02:52 PM
Weight 1987 34' Excella 83Excella 1987 - 1989 Excella 6 03-26-2003 07:43 PM
weight specs for 68 Overlander 26D PeterH-79MH 1969 Overlander 5 02-08-2003 04:49 PM
71' Airstream Caravel 18' weight specs PeterH-79MH 1969-1971 Caravel 0 06-15-2002 07:28 AM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 09:51 PM
