Old 05-14-2015, 10:15 PM   #1
Idea's Avatar
2003 25' Safari
Greensburg , Kansas
Hitch jack will not operate
Our jack has power but it will not operate. Hope someone can help .
Idea is offline   Reply With Quote
Old 05-14-2015, 11:21 PM   #2
subfan1's Avatar
2019 23' International
La Habra , California
You may have a bad switch. I just replaced the switch in our Jack
I called the manufacture and they sent me a new switch via US mail at no charge. I replaced the switch and it's back working again.
2019 GMC Sierra Denali
2019 23CB International
subfan1 is offline   Reply With Quote
Old 05-15-2015, 05:46 AM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Have you checked the fuse to that circuit?
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 05-15-2015, 05:51 AM   #4
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
As above suggested, does it do anything? If it starts you might have bent it. Fuse is an inline, 3AMP, not an easy match. I carry two extras in my "fuse" kit I bought at an AS dealer.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 05-15-2015, 06:01 AM   #5
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
How do you know it has power to it? Did you check with a test light or a meter?
Reason I ask is that I had a similar problem - in fact I have had the same thing on two trailers, so perhaps it is common.
My mac would not work and yet a meter or test light showed that it was getting voltage. I checked the switch and it seemed fine.
The problem tired out to be a bad ground on one trailer, and a corroded power feed connection (wire nut) on the other trailer.
In both cases, the bad connections were "good enough" to operate a test light or a meter, but could not pass enough current to allow the jack motor to function.
Maybe that could be a possibility in your case.
Good luck with it ....... Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-15-2015, 09:16 AM   #6
2020 Classic 33
Box Elder , South Dakota
Call Barker Manuf and ask for customer service. Great service from them and as mentioned they will get you the parts quickly.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 05-15-2015, 09:27 AM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My jack uses an inline 30 amp slow blow fuse. Locally the only place I could find them was NAPA. When I had a problem with mine Barker sent me over night and free 3 fuses, 2 different switches and 3 little gears. Turned out that one of the contacts in the fuse holder had not been properly soldered. Easy fix once I found the problem.
MICHAEL
Old 05-17-2015, 10:21 AM   #8
Idea's Avatar
2003 25' Safari
Greensburg , Kansas
We replaced the fuse and it works fine. Thanks so much. The airstream community is amazing!
Old 05-17-2015, 12:50 PM   #9
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Glad that you were able to correct your problem, that being said, may I interject another jack situation.
Having power to the jack and it will only go up or down. There are 2 micro switches under the access cover, in my case #V3-3001-D8, (15.1A 1/2 HP 125V 1/2A 124VDC). The switches are to limit the up and down movement of the jack. After having 1 switch failed I ordered 2 and now have a spare. Better safe then sorry.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 09-09-2015, 06:56 AM   #10
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Just had the replacement switch fail in my Barker jack. That's two switches in two years. Both times it was the raise function that failed. On the first failure Barker were excellent - they sent me spare switches in the mail free of charge. Will call them again now that I have used all of the spares.
Anyone else have problems with the switch failing?
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
safe to operate genset in the back of a pickup? hlopez Generators & Solar Power 15 11-24-2018 11:02 AM
RM 2552 - not sure how to operate adwriter73 Refrigerators 0 08-16-2011 04:58 PM
How does this valve even operate? OregonArgy Waste Systems, Tanks & Totes 5 04-12-2008 09:29 PM
Help us learn to operate the solar system. ClayandPerry Generators & Solar Power 15 01-31-2008 10:37 PM
