Originally Posted by AYRSTRM2
About to pick up a 1979 30 ft Argosy this weekend.
It's currently 1000 miles away and want to arrive prepared for all eventualities, including that the electric hitch jack doesn't work.
Can someone tell me the outer diameter for the Hitch Jack? They started using 2.25 inch outer diameter tubes sometime in the past, but I need to know if the 1979 Argosys used the older 2 inch or the new 2.25 inch outer tubes. They are not compatible, as I have found in the past.
I do not have your answer.
In addition, the goal of being prepared for ALL eventualities, in my opinion is un-realistic. Dealing with the unknown is in it's self an issue because .... it is ..... well, you know, unknown.
With that said, traveling at distance to pick up a trailer is hours of boredom with the excitement of 20 to 40 minutes of connecting the trailer and leaving. If the tongue jack is manual, hopefully it isn't bend bad. If it is an electric jack that can be exciting. I have a portable jack with a bunch of scrap wood that I bring every time. (among other things) I know it works because I brought it to the event. The trailer is an unknown.
The trailer ('66 Overlander) that I did pick up that was over 1000 miles away was moved from some storage site to my TV using a farm tractor. After I arrived at the seller's place. The tractor operator dropped the tongue on a cut tree trunk. I lifted it with my jack, knocked away the tree trunk and slid the TV under the hitch. That Overlander with a dead battery had a power jack that was retracted. I believe the tube was 2". I discovered the jack worked when a good battery was connected. However when I picked up the trailer, all I wanted to do was get connected and get gone. I had a fair piece of driving ahead of me.
The best you want is to be able to retract that jack. As long as most of the lights and brakes work, you can deal the rest when you get home.
>>>>>>>>>>>>>>Action
