Old 05-17-2015, 01:11 PM   #1
Manheim , Pennsylvania
Hitch jack level lost fluid.
My hitch jack level seems to have lost it's fluid. This I assume is not water, do I need a new one to replace it? Would this be covered under warranty on a 2015? Thanks!
Jukeboxfun is offline   Reply With Quote
Old 05-17-2015, 01:17 PM   #2
Kevin245's Avatar
Your stab jack is typical gear driven. Either manual or electric. No fluids other than some grease.
Eleanor Roosevelt
Old 05-17-2015, 01:25 PM   #3
terryV's Avatar
2002 31' Classic
Monroe , Iowa
The level fluid is probably alcohol of some liquid that does not freeze at normal winter temps.
I would say you probably need a new one, as I have never seen one lose it's fluid unless it broke.
I have no idea if it would be covered by Airstream, but the manufacturer of the level should cover it unless you smashed it in some sort of accident.
terryV is offline   Reply With Quote
Old 05-17-2015, 02:31 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
The jack would be covered under the jack makers warranty. Contact them directly. Maybe they can send you a new one. I have found mine to be totally useless.
MICHAEL
Old 05-18-2015, 08:32 AM   #5
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
If the fluid came out with no damage to the level (glass or plastic) I would assume this would be covered under warranty. It has developed a leak. Refiliing it is not an option.
>>>>>>>>>Action
Old 05-18-2015, 08:42 AM   #6
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I think Airstream uses Barker jacks still. Contact Barker and they'll probably mail you one out free.
Kelvin
Old 05-18-2015, 11:13 AM   #7
2015 30' Classic
Traverse City , Michigan
Barker Mfg
1-269-965-2371, Tina answers the phone....she's great. You need a new cap.
TCAS is offline   Reply With Quote
Old 05-18-2015, 05:45 PM   #8
I took the level off and tilted it in all directions and did not see a bubble. I put it in my pocket and later after contacting the dealer went to place it in the refridgerator as they suggested, why I don't know. When I took it out of my pocket the bubble was there again. I put it back on the tongue jack. Weird, I would have sworn it was empty of fluid.
« Tongue Jack | Top | Jack »
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
lost my stabilizer jack speed wrench Brow324 Jacks, Stabilizers, Lifting and Leveling 9 05-20-2008 03:59 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
