Old 06-20-2014, 11:24 AM   #1
2004 30' Land Yacht Gas 30
Langley , British Columbia
HELP! Our stabilizing jack is stuck down!!
we have a 2004 land yacht MOTORHOME and our right rear stabilizing jack is stuck down. We have no idea what to do and are new to motorhoming!
thanks!
shelagh is offline   Reply With Quote
Old 06-21-2014, 06:41 AM   #2
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
is the hydraulic full, so it is holding the MH up? or can you release the pressure in the jack, but it won't retract to travel mode? If that is the problem try hitting it with a two by four.
We rented a MH years ago and had all sorts of problems with the jacks, sometimes 3 of 4 would come down. other times upon departure, one would stay down. We learned to get down on hands and knees and check. We were able to try, try again, and then with some manual encouragement, able to get them into travel mode. I didn't put them down again after that! Good luck!
RAH is offline   Reply With Quote
Old 06-25-2014, 07:25 AM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Likely the original poster with one single post on this issue has figured out a solution as it has been almost 5 days since they posted.
>>>>>>>>>>>>Action
Stabilizing jack 3/4 Drive Drill outdoors717 Jacks, Stabilizers, Lifting and Leveling 43 04-07-2013 11:58 AM
Need electric jack help....stuck. ohwally Jacks, Stabilizers, Lifting and Leveling 39 06-06-2011 05:01 PM
HWH Levellers Stuck Down- Help! andyleonard General Motorhome Topics 5 11-07-2010 01:29 PM
69 Stabilizing jack Dan Roach Commercial Listings 2 10-27-2005 07:38 PM
Stabilizing Jack Choice COArgosy78 Jacks, Stabilizers, Lifting and Leveling 17 03-11-2003 12:00 PM
