Old 03-09-2016, 06:35 PM   #1
2014 27' FB International
Healdsburg , California
Help! Jack won't operate on 2014 International
Hi
My Jack is inoperable at the moment. I'm plugged into shore power, battery is at 13.4, fuse looks good, and all wires seem well connected. What else should I do? Also, if wiring seems to be the problem, any details regarding this would be really helpful!
Would like to be able to hitch up & go to the sun!
Streamalong is offline   Reply With Quote
Old 03-09-2016, 06:49 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
The jack has a manual back up function. Check the ops manual or internet for info. It just takes a wrench.
Old 03-10-2016, 02:42 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Had that happen to someone at a rally. The fuse looked good but it did not test good. Check it with an ohmmeter.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-10-2016, 04:33 AM   #4
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
As Isbrodsky stated the fuse may look good but the filament in these little buggers is so thin it could be bad. I'd either check it or put a new one in and see if that helps, otherwise it's the hand crank, a special handle for which should be someplace in your trailer.
Bud
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 03-10-2016, 05:47 AM   #5
lewster's Avatar
Naples, FL , Hood River, OR
In addition to the great advise about the fuse, be certain that the jack positive wire is properly connected. It goes directly to a positive battery terminal. If the light on the jack is not working, you are probably not getting power to the jack head.
Old 03-10-2016, 06:29 AM   #6
Two To Tow's Avatar
2016 27' International
Gainesville , Virginia
Just had this happen, had to replace the switch as there was a short. Until you can do that, there's a wrench that should have come with your rig - my access to the manual controls is under the level at the top of the jack. Good luck!
Two To Tow is offline   Reply With Quote
Old 03-10-2016, 06:42 AM   #7
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
The jack, IMO, is an achilles heel.
Unless you have a cover for the head, the micro switches WILL eventually corrode and you'll find yourself in the fix you are currently in.
That said (assuming you have a Barker product), they are very good at taking care of you and pointing you in the right direction; selling you a $15 head cover which will pretty much take care of the problem.
I suspect they'll send you a set of replacement switches. I suggest you take a picture of the old connections, before you replace the old with the new (sometimes they even comp you with the switches).
Been there, done that.
Good luck!
Murrey
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 03-10-2016, 07:31 AM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The fuse for the jack motor is not too common, so one may visit several auto parts stores to find them. Carry a box of five spares.
Old 03-10-2016, 11:14 AM   #9
jackson center , Ohio
The fuse holder is on the side of Jack post. It takes a 30 amp slow blow fuse due to start current
Schu is offline   Reply With Quote
Old 03-10-2016, 02:00 PM   #10
Rugger's Avatar
2008 28' International
Box Elder , South Dakota
I had the same problem and had to replace the switch. Easy to fix.
Roger, Adam and our dog Shorts
2008 Intl 28 CCD
2018 Toyota Land Cruiser
"You are only young once, but you can stay immature indefinitely' - Ogden Nash
Rugger is offline   Reply With Quote
Old 03-10-2016, 02:08 PM   #11
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Good advise from all, but forgot one item.
Check tighten the mounting bolts; could be a bad ground!
Happened to me once.��
MelGoddard is offline   Reply With Quote
Old 03-10-2016, 03:34 PM   #12
Branson , Missouri
The EXACT slo blow fuse is hard to come by.
A call to Barker, and they'll more than likely, send you 3 of the OEMs.
2013 Suburban 2500
2011 23 FC FB
Old 03-10-2016, 04:56 PM   #13
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
NAPA carries the 30 amp slow blows as a normal stoking item. I have bought them in two different NAPAS and they knew exactly what I was talking about.
MICHAEL
Old 03-10-2016, 05:58 PM   #14
1970 25' Tradewind
anderson , South carolina
Power jack does not operate
Had the same problem at the koa Bristol Tenn at race time. Had good supply of
12 volt power but would not operate. Removed the motor and all looked good
So gave a teat run with it off the tongue worked good. Solved the problem by
Cleaning the ground wire at screw connected on tongue. Moore problem
BobC
Bob Cooke is offline   Reply With Quote
Hitch jack will not operate Idea Jacks, Stabilizers, Lifting and Leveling 9 09-09-2015 06:56 AM
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 09:19 AM
How does this valve even operate? OregonArgy Waste Systems, Tanks & Totes 5 04-12-2008 09:29 PM
safe to operate genset in the back of a pickup? hlopez Generators & Solar Power 9 04-07-2008 01:38 PM
Help us learn to operate the solar system. ClayandPerry Generators & Solar Power 15 01-31-2008 10:37 PM
