Old 03-10-2016, 07:02 PM   #15
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Our jack failed on our 2nd trip. Fuse, switch and ground were fine. The motor had failed and had to be replaced. In our case it was covered under warranty.
SeaLevel is offline   Reply With Quote
Old 03-10-2016, 07:27 PM   #16
2010 27' FB International
La Crescent , Minnesota
Had the problem. it was the negative at the mounting bolts. Removed them one at a time. Cleaned area around bolt head. Replaced with stainless steel bolt.
Jay
mjayjensen is offline   Reply With Quote
safe to operate genset in the back of a pickup? hlopez Generators & Solar Power 15 11-24-2018 12:02 PM
Hitch jack will not operate Idea Jacks, Stabilizers, Lifting and Leveling 9 09-09-2015 07:56 AM
elec jack won't work, manual override won't budge? Randjg1 Jacks, Stabilizers, Lifting and Leveling 17 07-04-2009 10:19 AM
How does this valve even operate? OregonArgy Waste Systems, Tanks & Totes 5 04-12-2008 10:29 PM
Help us learn to operate the solar system. ClayandPerry Generators & Solar Power 15 01-31-2008 11:37 PM
