Old 04-02-2006, 08:35 PM   #1
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
Question Grinding noise from power jack
We have a H&H power jack... don't know if its original as we're the second owners.
The jack occasionally, and briefly, makes really bad grinding noises, but otherwise seems OK. Anybody have experience with this?
We 're about to head out on a couple of trips - some far from home - and don't want to be stuck with a broken jack. Our Blue Ox WD hitch WON'T uncouple without the use of the jack, and I'm worried that if the gears strip, the emergency crank won't work either.
Appreciate any feedback from people who may have experienced this.
Tin Diesel is offline   Reply With Quote
Old 04-03-2006, 05:33 AM   #2
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
You should have a separate manual jack wrench that you can operate the lift without power. The crank part should be located under the red cap on the top of the lift. I just used my wrench set with an extension and it worked fine, (although I found my jack wrench after the fact) It is very easy to use as I was just there. Mine was acting a little finicky and I figured it may have been raised up to much and I was getting that stripped gear sound. I didn't want to do any further damaged so I grabbed my manual lever and lowered it very easily. I'm pretty sure that was the prob because it worked fine after it was lowered. Hope this helps!
enduroryda is offline   Reply With Quote
Old 04-03-2006, 09:11 AM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
What's in your toolbox?
Originally Posted by kjmorle
We have a H&H power jack... the jack occasionally, and briefly, makes really bad grinding noises, but otherwise seems OK. Anybody have experience with this? - and don't want to be stuck with a broken jack.
By all means, practice raising and lowering your jack manually prior to your next trip.
Some jacks require a set of hex wrenches to remove the head to access the manual drive....make sure you have all of the tools required to raise and lower the jack before you get out in the boonies.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 04-03-2006, 06:48 PM   #4
Try removing the cover and the putting lubrication on the exposed parts that mate with the cover. I had a similar situation and the lubrication made a big difference.
1985 25' Sovereign
Corner Bed
2003 3/4 ton Suburban
6.0, 3.73
Bellingham, WA
alan is offline   Reply With Quote
Old 04-03-2006, 07:31 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
A Suggestion
It will help a lot in the manual mode if you disconnect the battery power that feeds the jack motor. It acts like a brake when not in use and locks the motor. I have to do this on a regular basis if a jack or slide-out motor is bad and it has to be retracted manually. The cranking is a lot easier if you de-power the motor first.
Power Jack Problems Daniel Conroy Electrical - Systems, Generators, Batteries & Solar 4 04-15-2004 10:40 PM
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Another Power Jack Question. 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-15-2002 10:23 PM
Power Jack Question 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-11-2002 06:05 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
