Originally Posted by cabdaddy
Any suggestions for a good jack to use on our 2019 Sport 22fb?
Are you asking about a jack to change tires on the trailer with, or a tongue jack used to raise and lower the front of the trailer for hitching and/or leveling?
If you are talking changing tires, a good lightweight floor jack as used for cars, or a hydraulic bottle jack can be used. Anytime you have a heavy vehicle in the air and need to work under it, jackstands are mandatory for safety. Any hydraulic or mechanical jack can fail, and that's not a good way to be trapped under something you can't lift all by yourself...
My preference is a combination bottle jack and jackstand like this:
https://www.amazon.com/Alltrade-6409...mbination&th=1
One of these can easily lift one side of an Airstream. I own two for heavy work on my 22foot dual axle 2007 International CCD that weighs around 6,000 pounds...my jackstands are rated for 6000 pounds EACH. There are lesser options on that link. Choose wisely.
Yes, a 6000 pound capacity PER JACK is massive overkill, mainly because I don't like taking chances on being hurt by a falling trailer.
On the road, I carry just one for tire-changing if I can't find a safe place to use my ramps to change out a single tire or if I blow out two tires on one side--which can happen with some road debris. This is a self-locking jackstand with a bottle-jack built in. Easy to operate, and has a solid, flat steel baseplate so it won't sink into the ground easily.
Be sure you jack your trailer from the MARKED jacking points on the Airstream frame to avoid damaging the frame, bellypan, etc. NEVER jack under the axle tube--it will bend and screw up your wheel alignment at minimum, destroy the axle at worst...research a bit to learn how to do it safely BEFORE you need to change out a flat, etc.
