Old 12-22-2015, 06:35 PM   #1
2017 25' Flying Cloud
1964 17' Bambi II
Ogden , Utah
Floor jack advice
We recently purchased a 2016 Airstream Sport 22 ft. trailer. With the purchase of our new trailer we have a 2 yr coverage plan with Coachnet included with our new trailer. We also just purchased a 2 & 1/2 ton floor jack, lifting capacity 5,000 lbs. Do most Airstreamers carry a jack when traveling or relay on the towing ins.? Do we need to have this large of a jack? Thanks for input.
mcaslaon4449 is offline   Reply With Quote
Old 12-22-2015, 06:41 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I carry an 6 ton bottle jack. It takes up way less room.
CRH is offline   Reply With Quote
Old 12-22-2015, 06:44 PM   #3
Goal15's Avatar
Dallas , Texas
Floor jack advice
I use the bottle jack that's in my Tundra
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 12-22-2015, 08:37 PM   #4
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Yes, we carry a bottle Jack, plus wood blocks to give it a stable base, and raise it. Also a wood pad to go between the Jack point and Jack. I hope to not have to use it, but would rather drive up on a block ramp to lift the tire off the ground (tandem axle).
Old 12-22-2015, 08:43 PM   #5
Mission , Texas
Floor jack advice
A 2-1/2 ton floor jack wouldn't lift our 27', so we got a 4 ton and park it under the goucho.
I would never use a bottle jack to lift a vehicle, seen too many accidents.
nrgtrakr is offline   Reply With Quote
Old 12-22-2015, 08:57 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
A bottle jack is a far sight more safe than those little floor jacks they sell at every big box and discount parts store...
#justSayin
Besides, if a person is going to put ANY PART of their body under a trailer or vehicle, a jack stand MUST be used.
Brevi tempore!
Old 12-23-2015, 12:10 AM   #7
2004 28' Classic
Medical Lake , Washington
We have a heavy duty bottle jack. The jack can lift a loaded trailer and tow vehicle if we have a flat. Hope to not ever have to use it. I have never had good luck with a floor jack on dirt or gravel. The wheels don't roll so the jack will Pull and push when lifting the load when raising or lowering since the wheels can not move in the dirt or gravel. Don't have that problem with a bottle jack. The bottle jack weights a lot less than an equal sized floor jack and takes up a lot less space than a floor jack. We have wooden pads that we put under the stabilizers that can also be put under the bottle jack. I replaced the small Tundra bottle jack with the larger bottle jack and store it in the same location.
Classic2004 is offline   Reply With Quote
Old 12-23-2015, 05:48 AM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up ....22' as
With our single axle 22' Safari I carried these....
And one of these...
But this also might be an option....with a jack stand.
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-23-2015, 07:21 AM   #9
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I used to carry a trolley jack and axles stand, but then switched to using Lynx levellers and feel that to be an easier and safer alternative.
You need two sets of ten each to make a pyramid to put one wheel on top then the other hangs free for easy removal. Of course you need a dual axle trailer for this method!
I still carry a small bottle jack as well though just in case I have some problem with the power tongue jack that cannot be resolved with the manual hand crank provided - maybe I am overly pessimistic
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-23-2015, 07:30 AM   #10
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Get a small bottle jack , how are you going to wrestle a floor jack around on rough pavement or gravel? A 12 ton will set you back $28 at Tsc.
Old 12-23-2015, 08:43 AM   #11
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
Why not use one of these? I have not had to use it yet other than to make video (knock on wood) but it does exactly what it is supposed to do...and easily.
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 12-23-2015, 09:06 AM   #12
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
The 22 ft. Sport is a single axle trailer so if a tire needs to be changed a jack will be required.
On two axle trailers the ramp idea works great - I've done it several times over the years.
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 12-23-2015, 10:30 AM   #13
Manassas , Virginia
DOH! I did not even pay attention to what model the OP listed. Sorry for going off topic.
Old 12-23-2015, 10:37 AM   #14
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
What type Jack does your TV have? You might be pleasantly surprised.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
To Jack or not to jack? Zstream Jacks, Stabilizers, Lifting and Leveling 7 12-17-2009 11:09 AM
Looking for a floor jack recommendation Globie64 Mechanics Corner - Engines, Transmission & More... 4 02-13-2008 05:46 PM
Should I trash my Sears floor jack? Kistler Our Community 35 08-05-2007 06:28 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
