Old 12-23-2015, 12:00 PM   #15
Mission , Texas
Again, I offer observations about floor vs bottle jack ...
Bottle jacks are harder to move in and out under a vehicle and they require more space between the floor and the bottom of the vehicle for clearance. You can't even begin to fit a bottle jack under most average size vehicles as there isn't enough room under the frame.
Also, as you raise a vehicle up there is movement since the vehicle raises in an arc motion. A bottle jack is stationary and therefore it could result in the vehicle slipping off of the lift point or the jack tipping. Floor jacks often have wheels and can slide to prevent any movement.
Add to this that floor jacks have longer handles allowing for faster jacking action and that they generally have a larger range of motion (a 5" tall floor jack might have 15" or more of lifting height for example)... it just seems they are better for working on vehicles.
Bottle jacks have their purposes - but it is generally on heavier equipment or stationary uses such as raising a building or acting as temporary support for a structure. Floor jacks are just better and more efficient for working on the average vehicle, so that is likely why you tend to see more of them in garages.
nrgtrakr is offline   Reply With Quote
Old 12-23-2015, 12:14 PM   #16
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
8 ton bottle jack
With a flat on the road I have used the orange Legos to get one wheel off the ground. Handy as the trailer is hooked up to the truck.
After being hooked up in our spot last August, I noticed a screw stuck in the tread of one tire. The bottle jack was just the ticket for changing the tire while hooked up in a grass spot.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-23-2015, 02:39 PM   #17
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Just looked. Mine is a 12 ton. Fits in the front corner of the truck bed.
Old 12-23-2015, 04:20 PM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Bottle jacks give more lift for the dollar and space. The draw back is they are less stable than other jack types. And on un-surfaced roadways the bottle jack has a bigger disadvantage in stability. However a flat piece of ply-wood under the bottle jack can help.
Typically a bottle jack will fit under almost any trailer so this becomes a common usage. Vehicles especially fuel efficient cars that sit low to the ground a bottle jack is not usable for that scenario.
Multi-axle trailers almost never need any jack as rolling one axle/tire set on a small ramp is the typical solution. (as mentioned above)
So one solution does not apply to every vehicle on every surface. Using the correct lifting device correctly in the situation will go along way to taking care of your baby.
>>>>>>>>>>>>>>>Action
Old 12-23-2015, 07:14 PM   #19
2012 30' Classic
Homosassa , Florida
I carry a drive up trailer jack to lift the opposing axle off the ground. I also carry a 12T bottle jack in case I need a jack.
Tater is offline   Reply With Quote
Old 12-25-2015, 01:54 PM   #20
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
For single axle trailers I wonder if there's a heavy-duty one of these available? See pictures and web site link below.
Echo Trailer Jack
ID:	254601   Click image for larger version
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 12-26-2015, 01:10 PM   #21
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
That thing would scare me....
Brevi tempore!
Old 12-26-2015, 01:29 PM   #22
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
That device is for round tube not square tube axles.
Old 12-26-2015, 07:18 PM   #23
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
I thought the same thing and it's certainly demonstrated on a round tube axle. Their web site indicates it works on square tubes too. Regardless, it seems to be for lightweight trailers.
Lucius and Danielle
Old 12-27-2015, 07:20 AM   #24
KYAirstream's Avatar
Northeastern , Kentucky
Floor jack advice
Originally Posted by ROBERT CROSS View Post
And one of these...
I like that scissor jack. When placed under the axle mounting plate, does the handle extend far enough past the tires to make lifting relatively easy?
KYAirstream is offline   Reply With Quote
Old 12-27-2015, 08:30 AM   #25
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Lots of ways to do this, but if your TV is a pickup or heavier SUV, please take a serious look at the jack you already are carrying. Is it strong enough? consider is was built to lift one wheel with a load in the bed. I know I mentioned this before. So in reality for me, I'm carrying two pickup truck jacks from a 1 ton and my own 3/4 ton TV. And they have done double duty and been used for fine tuning the leveling.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 12-27-2015, 09:26 AM   #26
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
10 ton bottle jack, if too tall, drive up on a block of wood, why keep trying to invent the wheel and the floor jack is best left in the shop on the floor...
Old 12-27-2015, 11:57 AM   #27
Floor jack advice
Keep it simple, I use a 12 ton bottle Jack on my 34 footer and use wood blocks for height adjustments
0557 is offline   Reply With Quote
To Jack or not to jack? Zstream Jacks, Stabilizers, Lifting and Leveling 7 12-17-2009 11:09 AM
Looking for a floor jack recommendation Globie64 Mechanics Corner - Engines, Transmission & More... 4 02-13-2008 05:46 PM
Should I trash my Sears floor jack? Kistler Our Community 35 08-05-2007 06:28 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
