Old 02-24-2019, 04:14 PM   #1
2015 30' FB FC Bunk
Baton Rouge , Louisiana
Electric vs Manual jack
My Barker 3000 hitch on our 2015 30í Flying Cloud bunk is blowing fuses.
Iím thinking of replacing with a manual hitch - one less thing to potentially break on the road.
Am I crazy to consider going manual?
Thanks in advance.
andyvignes is offline   Reply With Quote
Old 02-24-2019, 04:22 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Crazy, canít say. We havenít had campfire together.
But before you go manual take a look at the Husky jack. Itís the bees knees IMHO.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-24-2019, 04:36 PM   #3
2015 30' FB FC Bunk
Another question - will the trailer be able to manage both 2 and 21/4 inch posts on jack?
Old 02-24-2019, 05:11 PM   #4
Mollysdad's Avatar
Yes. All jacks that I've seen have three attachment bolts, 3/8" x 16, on 3" centers, so any jack will plug in the same holes. The Airstream will accommodate both 2" and 2 1/4" posts.
Can a manual jack handle 1000# tongue weight? It may be harder to crank than you'd like.
Now, I'm lazy and I switched to the Husky 5000# jack which is overkill (or not) but I'm spoiled having the remote control for the jack. Sit inside and level front to rear. Amazingly, the Husky 5000 is not much more expensive than your vanilla jack brand if you shop online.
Old 02-25-2019, 09:32 AM   #5
Annapolis , Maryland
Check the wires.
Our jack was blowing fuses until I discovered that the wire exiting from the propane box was chafed. I remedied that and the jack has been happy.
rhpeahl is offline   Reply With Quote
Old 02-25-2019, 10:07 AM   #6
Rhino33's Avatar
1980 31' International
1966 22' Safari
Cincinnati , Ohio
This is a question we have been asking ourselves lately. We have been having difficulty with the original electric jack on our 1966 22' and have considered going to a manual jack. The fuses all appear to be good, but plan on replacing each of them just in case and double checking the wiring on the tongue. The last few times we used it it sounds like it is very weary... This jack is frustrating in that we cannot figure out how to disassemble it enough to manually crank it as we could with our 1980 30'.
Robb, Jenn & The Brown Dog (Dex)
Maizie, The Black Dog, May You Rest Peacefully
1980 International 31
1966 Safari 22
WBCCI #4447
AIR #70157
Rhino33 is offline   Reply With Quote
Old 02-25-2019, 11:06 AM   #7
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
With great love and respect, Yes!
fwjumper is offline   Reply With Quote
Old 02-25-2019, 11:18 AM   #8
GCinSC2's Avatar
To replacing the jack or the crazy question?
S/OS #001
Old 02-28-2019, 06:09 AM   #9
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Crazy for considering a manual jack..........
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 03-01-2019, 07:09 AM   #10
2015 30' FB FC Bunk
Maybe I'm a bit jaded re maintenance at the moment - my propane hoses were dry rotted when I went to refill my propane tanks, and my automatic awning is on the fritz on top of the jack going a bit nuts. Less automation hopefully leads to less maintenance, fewer things breaking.
I've swapped out the electric jack for a Bulldog sidewind 5000 lb manual jack. If nothing else to get things operational while I fix the Barker.
A detail I was never able to find in the Bulldog spec: I raise the tongue of the trailer about an inch for every 10 rotations of the handle.
It's pretty easy. I can imagine that at some point in my life I REALLY won't want to use a manual jack. But right now it's not much trouble.
Old 03-03-2019, 08:28 AM   #11
Rhino33's Avatar
1966 22' Safari
Cincinnati , Ohio
Thanks so much for the recommendation, Andy! I'll take a look for one...
1966 Safari 22
WBCCI #4447
AIR #70157
Old 03-03-2019, 09:50 AM   #12
2017 19' International
Tallahassee , Florida
I'd prefer a manual jack. As said, one less thing ...
If the jack on our 19 ever gives up, I will replace it with a crank.
WhereStream is offline   Reply With Quote
Old 03-03-2019, 10:19 AM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
No way I would want a manual jack. Just replace it with a electric jack that works. Plus I use the electric jack to tension the WD bars each time. It is hard to guess what is going to go wrong on an Airstream. And manual jacks can fail also.
Bill M. is online now   Reply With Quote
manual crank for 1964 electric tongue jack Croverlander 1960 - 1964 Overlander 15 04-09-2014 11:10 AM
Tongue Jack..Electric vs Manual TankerIP Jacks, Stabilizers, Lifting and Leveling 9 05-29-2010 09:11 PM
Electric Tongue Jack Manual Override overlander64 Jacks, Stabilizers, Lifting and Leveling 10 05-07-2009 09:22 AM
replacing manual tongue jack with electric Lumatic Jacks, Stabilizers, Lifting and Leveling 5 11-25-2008 07:04 AM
Electric/Manual Jack Security Question docbluedevil Jacks, Stabilizers, Lifting and Leveling 1 11-01-2003 11:50 PM
