Old 04-28-2009, 07:00 PM   #1
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Electric Tongue Jack Manual Override
My Overlander has languished for the past few years while my Minuet traveled most everywhere with me. This year, the Overlander is going to be my primary coach for travel. My ten year-old electric tongue jack is acting up, and I need to be prepared with the correct size socket to operate the square drive manual crank. I believe that the jack is a Barker Ultra-Fab or its predecessor. There are no markings on the jack and the only labels have been obliterated by weather -- all that remains is the twin blue line border around one of the labels.
Does anyone know the socket size needed for the square drive manual override found below the circular rubber plug on top of the jack?
I am including a photo of the tongue that is the best photo that I have the jack in question.
Any suggestions will be greatly appreciated!
Kevin
Kevin D. Allen
AIR #827
Old 04-28-2009, 07:36 PM   #2
Kevin245's Avatar
Kevin,
It looks exactly like the "Hi-Torque" Acme Power Jack by H&H Engineering ( Division of Barker) on my 73 Avion. The Owner's Manual shows the crank handle (PN 21047) but does not give a size. The Avion is at our remote site until May 11th. If no one comes up with the information before then, I will send it to you when I get there.
Regards,
Kevin
PS... I still say you should have kept the 6E59 WBCCI numbers
Eleanor Roosevelt
Old 04-28-2009, 08:56 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Kevin
Your jack looks like the one on our Caravel. Does it have the little plastic cover on top that you remove to get to the square drive? If so, I think it is either 3/8 or 7/16. Take the little cover off and find the size using an open end wrench.
Ours came with a crank that is the proper size. I can check ours the next time I go to the trailer (one or two days) and let you know what size ours is.
Old 04-28-2009, 09:25 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Kevin, I have that jack on our Sovereign. I'll pull out the crank handle, and see if I can size it for you.
Old 04-29-2009, 07:40 PM   #5
Well Preserved
1993 21' Sovereign
Kevin, that square drive manual override is a 3/8" square, and a 3/8" socket extension fits directly over it, with no sloppiness.
Old 04-29-2009, 08:15 PM   #6
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Terry!
Thank you!! That is the information that I needed. I will be shopping for this weekend's Rally tomorrow and will add a 3/8" socket set to my shopping list.
Kevin
Kevin D. Allen
AIR #827
Old 04-29-2009, 08:35 PM   #7
Well Preserved
1993 21' Sovereign
Originally Posted by overlander64 View Post
Greetings Terry!
Kevin
Kevin, it is the female end of the socket that fits over the override. You might be able to find an 8 point 3/8" socket, or possibly the double female joiner that fits between the two halves of a cheap distributor wrench. it is 3/8" square, and male.
Old 04-29-2009, 09:00 PM   #8
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Terry!
I am assembling a streamlined toolkit to carry when towing with my Cadillac -- to be such a huge car it has an unusually small trunk. I will check my tools that survived the flash floods of 1993 (a roaring stream washed through my garage redistributing everything throughout the valley where I lived at the time). I don't believe that many of my mechanic tools survived, and I haven't replaced many since my time has been limited on mechanical projects. A compact 3/8" drive socket set may be just the thing to fit in the top tray of the toolbox that I plan to carry in the trunk of the Cadillac.
I certainly appreciate your help!
Kevin
P.S.: I think that I may have found the problem that is causing the jack to be temperamental -- the switch seems to be moisture sensitive -- each time the problem has appeared it has been during damp or rainy weather -- we had hot sunshine this afternoon and the jack worked like a charm for the first time this week (we have had rain every day except this afternoon -- we had very dense fog this morning and the jack refused to operate until it had been in the sun for several hours).
Kevin D. Allen
AIR #827
Old 04-29-2009, 10:19 PM   #9
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Craftsman makes 8 point sockets. Buying a single one the correct, 3/8", size should not be expensive. They should be in stock at the nearest Sears.
The correct size for an individual tab also makes a good tap driver with a ratchet or speed handle. You may want to buy more than one.
Vaughan
Old 04-30-2009, 08:35 AM   #10
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
My Bambi didn't have the manual crank for the electric jack when I bought it so I emailed the manufacturer, explained my situation and asked if I could get one from them. They replied by sending me one at no charge. Guess they like streamers...
mojo is offline   Reply With Quote
Old 05-07-2009, 09:22 AM   #11
1959 24' Tradewind
1967 17' Caravel
San Antonio , Texas
i'm have been looking for a new jack and don't want to cut loose of alot of cash. ebay has a bunch and most are reman units and the seller won't tell me what has been remaned if it's the gears i don't want that problem again. the ultra fab seems to be the least expensive at around $125 + shipping. also will a 3000# rating work?
Pablo
pablo is offline   Reply With Quote
manual crank for 1964 electric tongue jack Croverlander 1960 - 1964 Overlander 15 04-09-2014 11:10 AM
replacing manual tongue jack with electric Lumatic Jacks, Stabilizers, Lifting and Leveling 5 11-25-2008 07:04 AM
Electric tongue jack help RVnDixie All Argosy Trailers 8 12-31-2006 08:54 PM
Manual Tongue Jack Failure Sugarfoot Jacks, Stabilizers, Lifting and Leveling 38 11-30-2006 07:09 AM
Electric Tongue Jack darryl97420 Jacks, Stabilizers, Lifting and Leveling 0 05-25-2006 08:57 PM
