Old 05-05-2010, 02:14 PM   #1
nynick52's Avatar
1973 Argosy 24
Adrian , Michigan
Electric Tongue Jack
Can anyone recommend an electric unit? I have yet to read a good review; everything from it doesn't work in humidity to I have to hand crank most of the time.
I'm done hand cranking, but want to buy a dependable unit with a light.
Nick
____________
Nick & Lorraine
nynick52 is offline   Reply With Quote
Old 05-05-2010, 04:15 PM   #2
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Tongue Jack
I installed this jack a year ago. It has worked GREAT! I am satisfied with it. Easy to install. Bill
Atwood Power Tongue Jack 3500 lbs Heavy Duty RV - $229.79
When you get a chance to "Dance" or "sit this one out".......I hope you DANCE!
lebolewis is offline   Reply With Quote
Old 05-07-2010, 06:22 PM   #3
nynick52's Avatar
1973 Argosy 24
Adrian , Michigan
Any other recommendations out there?
Nick
____________
Nick & Lorraine
Old 05-07-2010, 08:46 PM   #4
JimW's Avatar
1997 30' Limited
Omaha , Nebraska
I've had Barker jacks on two trailers. The 13 year-old jack on my recently purchased AS decided it would only raise the trailer and not lower it. Air forums suggested I needed a new switch, and that i should call the company about the problem, which I did. So even though the jack was at least 13 years old, Barker sent a new switch free of charge. On top of that, I mentioned the circular bubble leveling thingy that sits on top of the jack was old and yellowing and I wanted a new one which I offered to pay for. Barker sent me a new switch, a new bubble leveling thingy, and, surprisingly, a new limiter switch. They sent the parts to me to at a campground I chose in NM where I installed all the parts. All of this was done at their expense. By the way, the jack is working great and I expect it to last for a long time. I recommend the Barker jacks because of their customer service.
Hand cranking tongue jacks is for the birds.
JIM
Rig: '97 30' Limited
Towed by: '13 Silverado 2500 Duramax
WBCCI #22116
JimW is offline   Reply With Quote
Old 05-07-2010, 10:24 PM   #5
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
I have a Barker VIP3000 and it works great. I had a similar story as JimW on service. When I moved unexpectadly I lost the hardware package with the bolt, spacer and lock washer and called Barker and and wanted to buy a kit. Bingo I had a package free of charge in 3 days. You can't beat that kind of service.
arcamedies is offline   Reply With Quote
Old 05-07-2010, 10:55 PM   #6
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Now there's a company that knows how to advertise with customer service. Hmm, the dirt contractor on the job site was wondering about an electric jack on his utility trailer yesterday, I watched him turn seem like a hundred turns per inch. Hey Rich, try Barker.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 05-09-2010, 08:41 AM   #7
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I don't know what brand was used in '66, and it is still working in 2010. OEM
>>>>>>>>>>>>>Action
Old 05-09-2010, 09:45 AM   #8
aftermath's Avatar
Spokane , Washington
Another Option
Nick,
Take a look here. www.adth.com/jacks.htm
I had one of these on my SOB and it worked very well. It was, as I remember quite a bit less than the regular options on the market. This is a very legit company.
Dick
aftermath is offline   Reply With Quote
Old 05-09-2010, 12:04 PM   #9
richinny's Avatar
2011 34' Classic
that link is dead :-(
Ricky
Old 05-14-2010, 07:18 PM   #10
nynick52's Avatar
1973 Argosy 24
Adrian , Michigan
Just got the Barker 3500 and hope to install this weekend.
Nick
____________
Nick & Lorraine
Old 05-21-2010, 09:38 PM   #11
buffaloman's Avatar
1978 Argosy 24
1977 Argosy 28
Darrington , Washington
I want to install a Barker VIP 3000. do I have to run a separate wire from the battery to the jack? or can I use a wire from the seven way hitch? If so which one? Do I have to drop the belley pan if I run a wire?
buffaloman is offline   Reply With Quote
Old 05-22-2010, 06:52 AM   #12
nynick52's Avatar
1973 Argosy 24
Adrian , Michigan
I installed the Barker VIP 3500 last weekend and ran back to the battery. I didn't feel there was enough slack in the hitch line to successfully make a splice. I did not drop the belly, but ran back instead running adjacent to existing lines. Where I had noting to zip to, I used zip wire attachments (self adhesive squares that I glued to the pan).
Nick
____________
Nick & Lorraine
Old 06-06-2010, 06:42 PM   #13
nynick52's Avatar
1973 Argosy 24
Adrian , Michigan
Camped with the Barker VIP 3500 for the first time last weekend and it lived up to expectations. Happy to not be cranking any longer!
Nick
____________
Nick & Lorraine
Old 04-14-2011, 05:52 PM   #14
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Note for anyone happening on this thread -- don't consider powering a tongue jack any way but direct from the battery. The jack requires a 30 amp circuit with a 30 amp slow-blow fuse. It's doing a lot of heavy lifting and needs lots of current.
The Barker jack only requires one wire, the one from the battery. The ground comes from connection by a star washer between the tongue jack's flange and the a-frame.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
electric jack, electric tongue jack, tongue jack
Tongue Jack..Electric vs Manual TankerIP Jacks, Stabilizers, Lifting and Leveling 9 05-29-2010 09:11 PM
Electric tongue jack wiring goswick Jacks, Stabilizers, Lifting and Leveling 7 07-06-2009 01:10 AM
Electric tongue jack help RVnDixie All Argosy Trailers 8 12-31-2006 08:54 PM
Electric Tongue Jack darryl97420 Jacks, Stabilizers, Lifting and Leveling 0 05-25-2006 08:57 PM
Electric tongue jack not extending ipso_facto Jacks, Stabilizers, Lifting and Leveling 5 03-25-2003 11:58 AM
