Old 11-04-2018, 03:41 PM   #15
Niceville , Florida
Get use to it. Iím on my 3rd one. I have a 2017 Classic.
GeauxAS is offline   Reply With Quote
Old 11-06-2018, 04:18 AM   #16
Rhino33's Avatar
1980 31' International
1966 22' Safari
Cincinnati , Ohio
This is perfect timing for this post. We had the umbilical cord hooked up to our tow vehicle, but had the kill switch engaged for the trailer battery. The jack (original to our 1966 trailer) would not work. We turned on the trailer battery - nothing. We hooked the trailer up to city power and then the jack would work???
I'm thinking it may just be wise to replace the jack (particularly like the ones with a built in light), but don't want to get in over my head.
Thoughts?
Robb, Jenn & The Brown Dog (Dex)
Maizie, The Black Dog, May You Rest Peacefully
1980 International 31
1966 Safari 22
WBCCI #4447
AIR #70157
Rhino33 is offline   Reply With Quote
Old 11-06-2018, 08:51 AM   #17
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I just ordered new switches for my Barker jack. 6 years old and at the end of this season, it was getting temperamental on the ups/downs. If those donít work, Iíll replace the whole jack system. Cheap stuff first
Old 11-07-2018, 05:49 AM   #18
2019 26' Flying Cloud
Leland , North Carolina
Good morning all. My problem turned out to be the 30 amp fuse. When I first removed it it looked intact, but put in a new one and it worked. May have blown due to light left on when last parked. Will keep a supply of fuses!
Hastalavista is offline   Reply With Quote
Old 11-07-2018, 05:57 AM   #19
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
Thoughts?
Before you replace the jack, you should make sure you have 12V power to it.
Changing the Jack is pretty easy, but I wouldnít change it I didnít have to.
KK4YZ is offline   Reply With Quote
Old 04-09-2019, 10:22 PM   #20
CruizinDux's Avatar
Tracktown USA , Oregon
Originally Posted by SteveSueMac View Post
I just ordered new switches for my Barker jack. 6 years old and at the end of this season, it was getting temperamental on the ups/downs. If those don’t work, I’ll replace the whole jack system. Cheap stuff first
SSM, i took your lead...new switch a handful of the rubber toggle covers that seem to last only one winter and...woohoo..drum roll...a new vinyl cover to keep the moisture out. First cabin ��
Temperamental...no up, but down would work...then up would work...some times. It was a crap shoot. Never had to get the crank out on the 3 month trip but figured it was only a matter of time and certainly sure to happen at a time that was not of my choosing or convenient.
B
CruizinDux is offline   Reply With Quote
Old 04-10-2019, 04:04 AM   #21
W , New England
B
Congrats! Cover is a good idea. What did you get? Can you post a link? Thanks - Iíll follow your lead too
Old 04-10-2019, 08:55 AM   #22
CruizinDux's Avatar
I bought it from Barker
https://www.barkermfg.com/accessories.html
Not a big cover but sufficient to cover the likely h2o intrusion points...toggle, bubble and light crystal. The latter was showing moisture and Barker instructed me to remove, dry and install. I think mine was a bit loose and leaking at the edge vs from the top at the bubble. I went with the cover to protect the toggle covers which seem to last maybe a season, maybe not.
B
Old 04-10-2019, 10:13 AM   #23
Mollysdad's Avatar
I changed jacks when the Attwood left me hanging, literally.
It went up but not down. The crank would not budge. (except up).
So, out with the Attwood 4000, in with a Husky 5000.
It's a dream!
Old 04-19-2019, 04:51 PM   #24
CruizinDux's Avatar
B
here ya go. Nice, reasonable heavy duty. Big enough but not too big that it flails in the wind.
Name:	IMG_2655 (Large).JPG
ID:	338553   Click image for larger version
Name:	IMG_2654 (Large).JPG
Power jack quit working Scotty033x Jacks, Stabilizers, Lifting and Leveling 17 09-20-2017 09:05 AM
New Shurflo pump quit working? Lothlorian Water Heaters, Filters & Pumps 9 12-14-2008 06:08 AM
DC quit working in my new 64 Globetrotter GlobeTrottin Batteries, Univolts, Converters & Inverters 11 09-06-2007 08:06 PM
'96 LY fridge quit working airstream96 Land Yacht/Legacy Motorhomes 5 07-02-2007 09:05 PM
The ol' Dometic quit working... InsideOut Refrigerators 5 08-09-2004 05:07 PM
