Old 11-27-2007, 07:34 PM   #1
birmingham , Alabama
Electric Jack Question on '76 Safari
I have noticed that the electic jack works like a charm when hooked to a 12 v battery, however, when plugged into 110v (no on board battery), the jack will work at a very slow speed? Is this normal? Thanks.
thewarrens is offline   Reply With Quote
Old 11-27-2007, 08:35 PM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
A battery provides a lot of current and maintains reasonable voltage even at high current. I'm guessing your converter is pooped out or you've got some small guage wire between the converter and your jack.
Put a voltmeter on the 12 V wire to the jack as close to the jack as possible, then watch the voltage drop when you turn it on. You might have your partner then do the same, but measure the voltage at the output of the converter. If the voltage drops a lot more at the jack than it does at the converter, it's a wire problem. If they both drop, it's a converter problem.
Zep
Old 11-28-2007, 08:11 AM   #3
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
The convertor does not supply enough AMPS to operate the A frame jack. Being connected to your tow vehicle, or having a 12 volt battery in the AS should solve your problems. It is also best to have a battery in the coach when attempting to operate the water pump or furnace. Both require more than a convertor to operate properly.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 11-28-2007, 09:45 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
And to echo what has been posted above, since this devise needs a lot of power (amps) a long run of wiring is difficult to get that kind of power sent to the jack motor as compared to a battery pugged in near by. The length of wiring may be an issue in your comparison.
>>>>>>>>>>>>>>>>Action
Old 11-29-2007, 05:51 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Why are you running without a battery? The battery is the source of power while the converter is only the replacement of power in the trailer.
2004 Excursion 4x4
Electric Jack Question.. Dickandvicki Jacks, Stabilizers, Lifting and Leveling 13 10-24-2013 07:01 PM
Electric tongue jack for my `72 Safari Tom Bray Jacks, Stabilizers, Lifting and Leveling 3 10-14-2012 09:09 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
Electric/Manual Jack Security Question docbluedevil Jacks, Stabilizers, Lifting and Leveling 1 11-01-2003 11:50 PM
