Old 06-06-2006, 07:57 PM   #1
Pappy's Avatar
2006 25' Classic
Floyds Knobs , Indiana
Electric Jack operation?
OK, I have noticed on my Classic 25 at times that the electric Jack seems to get a forward or aft load on it. I may be over analyzing this, but I wonder just how much forward and aft movement this Jack can put up with. Chocking the wheels forward and aft is a given and finding level spots is not always possible. I suppose one could back the airstream against the chocks and place the front chalks into place to take away any slack.
Any comments?
Pappy
Pappy is offline   Reply With Quote
Old 06-07-2006, 10:26 AM   #2
The extended jack must be designed to take a degree of fore-and-aft loading as the load will only be purely along the tube when the tube is at right angles to the ground. When the tongue is raised right up, so as, for example, to fit the load distribution bars, there will be a considerable fore-and-aft bending moment, and the jack tube withstands this. I would not be concerned about this.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 06-07-2006, 10:55 AM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I think I would be concerned if the jack was fully extended and there was much that was not centered. In that case, I would use blocks under the jack.
Pat
pmclemore is offline   Reply With Quote
Old 06-07-2006, 12:22 PM   #4
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Not much side load...
The power jack isn't really designed for much other than vertical loads to raise or lower the tongue... If you're going to be inside the trailer and moving, or working on it from outside, the leveling jacks should be lowerd to brace it in position. They will block any side loads, and absorb some of the fore/aft loads, along with wheel chocks as others noted...
It's pretty easy to bend or collapse power jack by pulling trailer forward with jack extended (don't ask.. ) and it really is only designed for static vertical load.
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 06-11-2006, 07:14 PM   #5
Pappy's Avatar
2006 25' Classic
Thanks for the comments,
After this weekend of camping I have decided to try the scissor type of wheel chocks that go between the wheels. I am not satisfied with just loose chocks. And after watching the guy next to me do an uncontrolled roll back of his trailer off a stack of plastic blocks after he disconnected it from his tow vehicle, Yikes!
Pappy
Old 06-11-2006, 08:12 PM   #6
myoung's Avatar
Nipomo , California
Images: 24
I mistakenly started to drive off with the electric jack in the down position. Big mistake, of course. The jack was so bent that after a couple of more uses I failed to retract so I had it replaced.
I did two other things that help me remember what to do when setting up or leaving. First, I got a bright orange jack pad, one that is hard to miss when checking to leave. The bright object is a nice visual cue.
Also, I bought two between-the-wheel chocks that when locked in place really do a superb job eliminating the fore and aft rocking that happens when moving about inside the trailer or when parked on a less than level surface. I use these every time before disconnecting so no stress is placed on the electric jack.
So far my new practices have been working well.
Mike Young & Rosemary Nelson
Bowlus Road Chief "Endymion"
BMW X3 xDrive 28D
myoung is offline   Reply With Quote
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
Another Power Jack Question. 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-15-2002 10:23 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
