Old 06-19-2007, 03:58 PM   #1
dbradhstream's Avatar
2006 28' Safari SE
Winter Park , Florida
Electric Jack failure - what now?
Please let me know what your next step would be.
This past weekend my Barker Super Power Jack failed - wouldn't go up, wouldn't go down, I couldn't crank it by hand, nothing. I called a mobile RV service and eventually got a manual jack installed after a full day of hassle. Trailer is a 2006 still under warranty. I have Good Sam which would have covered towing but didn't call them b/c didn't want to be towed anywhere.
Son of a ...!! The bill, with mileage to and from, parts, service call charge, etc. came to over $300 - all to install a jack worth about $50. If only I'd known I could probably have done it myself, but I'm supposed to be under warranty so why should I have to??
Acc'd to RV tech, the Barker jack is shot - worm gear stripped or some such. Dead. Kaput. Seized up.
RV tech called my A/S dealer twice during the day to see if they'd foot the repair bill but calls were not returned.
Question: I think between Good Sam, my AS dealer and Airstream corporate, I should get reimbursed for what I spent. Who should I call first? Do you think I will be able to get reimbursed?
'06 28' Safari SE / '08 Chev 2500HD Duramax
'64 Me / '60's-ish wife / '90's kids / '06 Black Lab / '02 Poodle / oh, and a horse, too.
GO GATORS!!
dbradhstream is offline   Reply With Quote
Old 06-19-2007, 04:23 PM   #2
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
if you have had your unit less than a year you should be able to get reimbursed......but I'm not sure...Barker might send you another jack...make sure you fax a copy of your bill...you will also need your original purchase order from the dealer that shows your date of purchase...the warranty on the Barker Jack is 1 year from the date of purchase...you should have a Barker warranty card in your owner's manual.
Barker's address is:
730 East Michigan AVe
Battle Creek, MI 49014
Phone is 269-965-2371
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 06-19-2007, 04:49 PM   #3
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Given the cronology of events, read your Airstream warranty, determine which provisions, if any, cover this case, and then write a letter to airstream asking for reimbursement of the enclosed bills. Good Luck.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 06-19-2007, 05:37 PM   #4
Halimer
2006 25' Classic
New Hyde Park , New York
Electric Jack
I recently purchased a new 2006, Classic 25. My electric jack broke down one week after purchasing the camper and prior to going to the Metro NY Area WBCCI 50th Anniversary rallie. I used a small 5 ton floor jacket to get the camper on and off my hitch. I called Barker Industries the next day and they sent me a new one.
halimer is offline   Reply With Quote
Old 06-19-2007, 05:50 PM   #5
Warwick , Georgia
IF YOU GOT ANYTHING out of Barker I tried for three months to get them on the phone could not get customer service any one time I now use a house jack. Go buy a real jack!!!! Jim
Doctorpolish is offline   Reply With Quote
Old 06-19-2007, 06:01 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I never, and I mean, never (ok, rarely) leave home without a small hydraulic jack. Cost is maybe $25, but in that situation, would have saved you some time and $$$. Have used it many times both for the jack blowing fuses (due to short that is normal for these) and several other events that made me rethink why I didn't carry one.
Also carry some fuses!
When I was at the factory for service, one of my long list of items was the power jack keeps stopping. The tech told me, before he even opened it that it's common and had it fixed in a matter of minutes. Problem is that it still happens from time to time. A fuse and hydraulic jack saved the day at least 3x since spring of 2005.
Old 06-19-2007, 06:31 PM   #7
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Silvertwinkie:
I just want to say that you make a good point for those of us that have the electronic jacks. I will from this day forward carry a small hydraulic jack!
This is something you just don't think about until it happens!
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 06-19-2007, 07:27 PM   #8
Aluminut
2004 25' Safari
. , Illinois
Originally Posted by Safari-Rick
Silvertwinkie:
Tell me about it... I learnt that lesson when mine failed and I was up s** creek. I was so desprate, boondocking, in the middle of nowhere, I broke out the tow vehicle jack and managed to get 'er going (without the power jack) after some trial and error, but after that event, found the jack I left home all the time was my new best friend.
Glad folks find it useful, it's pulled me out of a few jams since that first time....of course, back then I didn't even carry extra fuses which in my first case would have solved my problem, so, I bring both now.
Old 06-19-2007, 08:03 PM   #9
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
I had a similar problem and I though my jack shaft was jammed in the post assembly. I sent it back to Barker and they fixed it under warranty.
It appears that in the winter when I move my trailer, I did it without using the DC power to jack it up/down. I manually used the hand crank. That is a no no unless you manually re-sync the shaft with the timing system. It stripped the fiber gears too. The shaft does not know how high or how low it is in relation to the tube assembly. You must re-sync it if you adjust the shaft and not the motor at the same time.
Since your unit is new, read the label on the shaft and read carefully the last page of the Power Jack instructions. This is not an unusual problem that we learn the hard way. And the warnning instructions should be in RED ink.
Good luck.
JStanley is offline   Reply With Quote
Old 06-19-2007, 08:08 PM   #10
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Silvertwinkie:
It is also useful for jacking to change tires on the single axle trailers. You can also use the old crank-around and around bottle jack-looking OEM truck jacks in an emergency.
Old 06-19-2007, 09:18 PM   #11
ScottW's Avatar
Hernando , Mississippi
Don't recall off hand which jack is on my 2007, but I called the mfg and had them send me a few spare 'slo-blow' fuses for the jack...just in case. This is one major cause of jack failure. FWIW.
Rgds,
Scott
Air 16426
Fully retired now!
Remember:
Never start anything before noon and always plan on being finished by 5.
I will never HAVE to be anywhere ever again!
ScottW is offline   Reply With Quote
Old 06-19-2007, 09:24 PM   #12
I have called Barker three times over the course of three trailers and more than a decade. The last time was last year when I actually emailed them because I had lost the parts bag for the jack that I bought brand new to install on my Argosy. Funny thing is, the other two times were for parts that I misplaced too.
Each time I called I talked to someone. My email was answered within one business day. Each time I explained what a boneheaded thing I had done and asked if there was some way I could pay for what I lost. Each time I was told that it was not necessary and they mailed it out that day. I live in MI so it takes one business day to get something mailed from Battle Creek.
I figure it beats what I have gotten out of Airstream. My brother-in-law took his 31 footer into them last year and one guy told him one thing and just as soon as he was gone another guy told him the exact opposite. Oh brother....
Anon is offline   Reply With Quote
Old 06-25-2007, 10:48 PM   #13
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Shorting out jack
While on the last night of our 23 night trip (4000 miles) our Barker jack went south on us. I found a blown fuse but putting another one in just caused that to blow also. I called Barker today and without any hesitation they said they are sending another head unit at no charge. She just asked if the old one (6 months old) shorted out. I think that this might be an ongoing problem and they are making good on a design defect. Any ideas? Should I plan on replacing this jack in the future?
altamont is offline   Reply With Quote
Old 06-26-2007, 09:10 PM   #14
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Same problem
Had the same problem a couple of years ago - contacted Jim Parrett @ Airstream and he gave me this:
"Barker at 1-800-537-9940 ext 314. This will bring you to Greg. He has told me that he would be happy to repair your jack head and send it back to you."
Had just drove in to our destination and was ready to set up but no powerlift (wheels were a'turning but no vertical motion). Had to take the top off and crank it manually (a godsend). Wondered what that little crank handle was for. My initial conversation with Barker was not too productive. Jim intervened and made it work - way to go Airstream. Didn't cost me a nickle.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
B.A.L. Jack TheBigRedTruck Jacks, Stabilizers, Lifting and Leveling 4 06-06-2002 01:34 PM
