Old 09-13-2015, 03:47 PM   #1
2014 22' FB Sport
Mpls , Minnesota
Electric jack diameter for Sport 22FB?
I'm getting close to pulling the trigger on an electric tongue jack, and have noticed two different sizes for post diameter, 2" and 2.25". I don't have access to the trailer at the moment to measure. Anyone know which size the Sport 22FB would have? Anyone have a favorite jack? Leaning towards Barker or Atwood. Seems like a lot of switch issues with the Barker though...
MN Jeff is offline   Reply With Quote
Old 09-20-2015, 07:34 PM   #2
2014 22' FB Sport
Mpls , Minnesota
Any 22FB owners know which jack diameter I need to look for?
Old 09-22-2015, 02:33 PM   #3
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
If a Bulldog Jack becomes a consideration we had a negative experience with it and will likely not buy it again.
We use the lifter bars as part of our hitch set up. One of the steps is to run the Jack up to a high position, put your chains into a link and the lift your bars into a set position. This usually works well with this exception.
The Bulldog Jack can disengage its gears when raised up beyond a certain point. There is not (currently) a marking on the jack post or a stopping point that indicates you should not raise any higher. When you are stuck at that extended height you can only use the manual version with a socket. On our case we applied do much twisting force we broke the upright manual post off.
I only found out about this Bulldog Jack glitch by googling for a fix and found several mentions of it. Bulldog acknowledges the problem and e trailer will exchange the damaged jack for no money but not sure we want another one.
Will decide soon if we will opt for a Husky Jack instead.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Airstream Sport 22fb :: 2013 Airstream Sport 22 fb boomerang1 Airstream Registry Discussions 0 07-21-2012 07:23 PM
Need Drain Hose Diameter for Penguin ASAP BrockLives Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-04-2011 05:59 PM
7" diameter tail light back plates Rosemary Lights - Interior & Exterior 10 04-15-2011 05:56 PM
Zip Dee Roller and Slat Diameter? Silverfly Awnings 5 04-24-2007 05:53 AM
Adding an electric jack to 2005 Bambi -- what diameter? platbr Jacks, Stabilizers, Lifting and Leveling 1 09-27-2005 03:40 PM
