May be time for a new Jack. What do I need and what should I pay?
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
Hi nifty -- This month there's been a behind the scenes project to divide all threads into more specific categories. Take a look at the forums page under Exterior Restoration and you will find a section on Stabilizers & Tongue Jacks to browse. This can be done by the handy DIY-er.
Take note of the inline fuse -- can't say where it'll be in your current setup.
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w) www.balrgn.com www.balrgn.com/Airstream.htm
Thanks for all the input.....all booked marked. Will the holes line up with any jack I buy?
I really wish I could say. If not, I would assume you could weld the old ones closed and drill out the new ones. I forgot what drill bit I used when I attached my dual cam HP system, but it went through like butter.
Ah, when our electric died, Camping World (granted, an expensive place) quoted several hundred for a new one. The manual jack ran $39, however. I decided that I could do a whole lot of manual jacking for that savings. No regrets since then.
Lynn
WBCCI 21043
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Eubank, started to hand crank too with emergency crank. No worrys, no problems.
