Old 01-06-2016, 04:56 PM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Electric jack
I have attached two pictures showing our electric jack turnt to the right. It appears that a screw has broken and now when being lowered it turn to the right. So I was wondering what is the best way to fix it. thanks for any assistance
John
ID:	255244   Click image for larger version
urnmor is offline   Reply With Quote
Old 01-07-2016, 10:53 AM   #2
2007 27' Classic FB
Ridgefield , Washington
Put the head back in position. Then tighten the hex screws on the lower part of the head. If one screw is missing, call the company and they will send a repacement hex screw. If this doesnt work, their customer service is very good.
John & Lisa
Woosch is offline   Reply With Quote
Old 01-07-2016, 11:15 AM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
You can probably get an extra screw from a auto parts or hardware store.
Old 01-07-2016, 05:01 PM   #4
urnmor's Avatar
Berlin , Maryland
My thanks to both of you I will look for the hex screw. I am not sure but I think it broke off. If it did in fact break do you know how easy it would be to remove the head. I might have to do this if art of the screw is broken off inside the male pole.
again thanks for your assistance.
Old 01-07-2016, 05:16 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Referring to the Barker Power Jack, The only thing that holds the head on are the 2 set screws. If one has broken off and the head is moving anyway you may be able to work the head back and forth to lift it off. If the set screw is broken off inside you may have to drill it out. You then might have to tap the hole for a new set screw of use a metal screw into the jack shaft to secure it.
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 03:02 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
Electric tongue jack not extending ipso_facto Jacks, Stabilizers, Lifting and Leveling 5 03-25-2003 11:58 AM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
