Old 03-14-2011, 01:46 PM   #15
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Protecting the Breakway & Jack Wiring
Once you get the repairs made to the wiring, you might want to protect the wiring to avoid this happening again...we did this on our rig. We bought clear flexible plastic tubing, slit it on one side and put it over the wiring for both the jack and the breakaway wires so that it doesn't rub against the propane tank cover, etc...then wrapped electrical table every 4 or 5 inches to keep it in place. Not taping it completely allows water to escape should it get inside the tube...
Name:	Jack&BreakAway Wiring_01_Sm.jpg
TB & Greg and Abbey Schnauzer
#3954
Old 03-14-2011, 02:39 PM   #16
reddogfox's Avatar
2008 20' Safari SE
Thumb Area , Michigan
Coloradoair
In addition to doing what TB Rich suggested, you might want to add plastic mounding to the bottom of the propane cover where it rests on the trailer frame. This will increase the space available for the electrical conduit and reduce the chances of the cover rubbing against the wires in the future.
Richard from MI
20' 2008 Safari SE, Dill TPMS Silver Dog House
2007 GMC 1/2 ton Sierra ARE Cap
AIR # 10494
reddogfox is offline   Reply With Quote
Old 03-14-2011, 03:12 PM   #17
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
That's a service type battery,so look closely at the cell cap(it does come off) make sure that the shorted wire did not burn a hole thru the cap. WHILE you are there check the water level under both caps and fill to the bottom of the openings with DISTILLED WATER ONLY. If there is a hole burned thru it will need to be plugged with some epoxy of some kind to prevent dirt from gettin in and battery acid getting out.Be careful There is Sulfuric Acid there .DO NOT TOUCH your face or eyes after handling the caps. WASH YOUR HANDS after working in this area.
Ask my wife she see's my ate up pants and shirts from battery acid I contact in my shop.
GOOD LUCK.
ROGER
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 03-14-2011, 06:53 PM   #18
nilesrob's Avatar
Marietta , Georgia
Images: 12
Great idea!
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 03-14-2011, 07:42 PM   #19
RonaldC303's Avatar
Washington , Utah
It appears the fuse would better protect if it was located closer to the battery. Has anyone installed a fuse at the connection to the battery terminal?
RonaldC303 is offline   Reply With Quote
Old 03-15-2011, 05:19 AM   #20
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
We used heavy duty in-line fuses direct to battery in my old TV when I wired in for the 7-way trailer connection. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 03-15-2011, 06:17 AM   #21
lewster's Avatar
Naples, FL , Hood River, OR
Remember that fuses should be located to afford maximum protection to the wiring and components that the wire feeds. When I re-did my battery box to accept the 220 amp/hour Lifeline golf cart batteries, I moved the fuse for the jack right into the battery box and changed the fuse type to a blade type 30 amp maxi fuse in a water-proof casing.
Also added wire loom to the +12VDC wire supplying power to the jack to prevent what happened to you. Just another 'shortcut' that Airstream takes when there are other, safer methods to wire a high-amp component like a jack.
Old 03-15-2011, 09:03 AM   #22
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Here is a piece of advice that some may find unhelpful. However I believe it is the best thing you could do right now.
Apparently you are not knowledgeable or experienced with working on 12 volt wiring. There is nothing wrong with this, except that it makes it difficult to utilize long distance troubleshooting help.
You do not need an Airstream Dealer to fix your problem. You simply need someone who is knowledgeable and experienced with Auto or RV wiring to help you.
It looks to me like something is not right with the way the wiring is done in your trailer. There should not be anything wired directly to the battery without a fuse or circuit breaker to protect the wire from the type of damage in your picture.
In my 2010 trailer there is nothing attached directly to the battery posts except the battery cables.
I would strongly suggest that you find someone local to you who can help you figure out what is actually going on.
If you still have your trailer manual, there should be a 12 volt wiring diagram in it. With that and a knowledgeable helper, you should be able to get this fixed in a very short time.
If necessary, use the jack crank that came with your trailer to operate the jack so you can tow it to any nearby RV or trailer repair place.
Ken
Old 03-15-2011, 11:42 PM   #23
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Apparently these jacks are not all wired alike. Mine has a wire directly on the battery terminal like the O.P., then it passes under the A-frame where it has an in-line fuse, then up past the propane cover (where it pinches and shorts out) to the jack switch. Lousy routing by factory.
I wouldn't move the in-line fuse inside the battery box though, because it could spark when it blows and ignite any hydrogen gas escaping from the batteries.
Doug K
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Need Tongue Jack - Suggestions? kj78133 Jacks, Stabilizers, Lifting and Leveling 16 02-23-2011 05:55 PM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
Docking Lights not working 396 XL Torpedo Family Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 13 02-04-2011 02:10 AM
