Old 03-22-2010, 07:51 AM   #1
2010 27' FB Classic
N/A , Texas
Drill Adaptor For Stabilizer
I've been looking around for an adaptor that I can use on my drill so I can attach it to the crank on the stabilizer to lower and raise the stabilizer when setting up and breaking down camp. I have had no luck finding one.
Where can I buy it?
And any other info so I could order one if needed.
Old 03-22-2010, 07:57 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Get a 13/16" sparkplug socket. And a socket adapter for drill of the proper size (3/8" depending on your sparkplug socket). Life on the easy lane...
5 meter Langford Nahanni
Old 03-22-2010, 08:08 AM   #3
2010 27' FB Classic
N/A , Texas
CanoeStream,
Thanks, I may even have those parts somewhere in the tool box.
Old 03-22-2010, 08:12 AM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Hi
I think my socket is 3/4 3/8 drive and the adapter for my cordless drill came from Harbor Freight. I do carry it but would rather use my 3/8 drive speed wrench.Its a little more effort but the only thing I have to recharge is ME. It takes up so little space in my curbside compartment,I have to search for it when I need it. Speed wrenches can be obtained from Harbor Freight,Sears,I have found several at our local flee market used for a couple of bucks.
Good Luck on your search.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 03-22-2010, 08:26 AM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Just an FYI, it's pretty easy to "overtighten" the stabilizers, both going up and down, with the drill. The stabilizer doesn't need to do much more than firmly contact the ground, or retract until it stops.
Old 03-22-2010, 08:31 AM   #6
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Good to know that. I was playing with the new ones I just put on the trade wind the other day and it lifted the thing off the ground in half a heart beat. I guess I am lucky the trade wind is light and I didn't tear the stabilizer up. I'm going to have to be careful with that, use a slower speed on the drill and so forth.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-22-2010, 08:38 AM   #7
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Set the clutch on the dril for 1/3 scale, if it has one. Adjust up or down from there.
Michelle TAC MT-0
Sarah, Snowball
Old 03-22-2010, 08:39 AM   #8
2010 27' FB Classic
N/A , Texas
Mikethefixit,
Good idea on an option, I really don't like that crank type wrench that comes with the stabilizers. Each time I finish setting up my back needs a rest.
Overlander63, I'll keep that in mind and set the torque low on the drill.
Old 03-22-2010, 08:51 AM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
I have been using an 18 volt cordless drill to lower and raise Lucy's stabilizers for years. This system works great, and I also use the same 3/4" socket on the drill to set the tension on my Hensley.
The little lug adapter I use to attach the socket to the drill was purchased a Sears. I have also recently purchased a set three of these at an Ace. There was a 1/4', a 3/8", and a 1/2" drive lug in this set.
I use the 1/2" drive to use the heftier 3/4"socket.
When lowering Lucy's stabilizers, I set the torque on the drill at a level that will not make them too tight.
Brian
SuEllyn & Brian McCabe
Old 03-22-2010, 09:42 AM   #10
Aluminum Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Pardon my Ignorance
Hi guys/gals,
Pardon my ignorance, but what is a speed wrench? Also if you are going to adjust the stabilizers manually, why wouldn't just use the crank that was supplied with your trailer.
Thanks as always
Malcolm & Randy
WBCCI # 12523
kamadeca is offline   Reply With Quote
Old 03-22-2010, 10:06 AM   #11
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Speed Wrench
Originally Posted by kamadeca View Post
Hi guys/gals,
Thanks as always
Basically a speed wrench is like your crank,just has an adapter on the end for 3/8 or 1/2 " sockets. Dave
easyride is offline   Reply With Quote
Old 03-22-2010, 10:16 AM   #12
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I bought my 3/4" socket with the "nub" on the end at a local RV Parts store. I've been using my 18v Ryobi for raising and lowering the stab jacks for a couple years now and love it. Don't know why I delayed it!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 03-22-2010, 10:30 AM   #13
_
Originally Posted by Bluto View Post
CanoeStream,
the cordless drive, adapters AND socket/s will serve double duty...
IF u plan to buy a PP or the older orange hitch...
http://www.airforums.com/forums/f464...tml#post521435
keep the drill/driver set to SLOW speed for either cranking job...
some guys also use the drill/socket adapter to spin LUG nuts on/off after loosening...
but it's very easy to bugger the stud threads, so beAware...
_________
hey bluto
has a/s DROPPED the electric stabilizers from the '10 classic limited?
or are they 'options' now that U must pay extra for ?
if so that's BS.
they keep DEcontenting these units and UPing the price...
cheers
2air'
Old 03-22-2010, 10:52 AM   #14
moosetags's Avatar
Hi guys/gals,
Thanks as always
Using a cordless drill for stabilizer duty probably saves about five minutes of set-up and break-down time when camping. Plus you gain the advantage of equal pressure on each of the four stabilizers once the torque on the drill is set the way you want it.
Brian
Clear hose adaptor Scott Hopkin Airstream Trailer Forums 9 08-21-2014 11:09 PM
Umbilical and 7 Pin adaptor issues LowellN Lights - Interior & Exterior 48 07-18-2010 11:20 PM
will i need an adaptor? ryan3326 Waste Systems, Tanks & Totes 1 10-05-2009 06:33 AM
1963 Overlander Electrical Adaptor / Brakes erikjware Brakes & Brake Controllers 1 02-22-2008 03:43 PM
'64 Overlander brake/signal lights adaptor NCCoaster General Repair Forum 1 08-30-2007 06:36 AM
