03-22-2010, 02:50 PM
#21
1993 34' Excella
Estancia
, New Mexico
Originally Posted by osolow
I would suggest getting a cordless impact driver(works better then a drill)
and have your socket tack welded to the adapter. also one thing i didn't noticed was
no one said anything about your stabilizers. make sure there not bent up to bad and
are greased up to make using the driver a lot easier
I'm not sure greasing the stabilizers is a good idea. Sounds like a dust, sand and grit magnet. Maybe a little silicone spray?
03-22-2010, 03:08 PM
#22
1958 26' Overlander
Mesa
I use silicone spray with good effect. Does not attract dust or dirt.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
03-22-2010, 04:54 PM
#23
_
lubing the screw jacks?
this is generation AND model and brand specific maintenance with various PROPER methods...
for example the modern (like the last 20 years) electric screw jacks,
have GREASE ZERKS and grease exit/overfill ports...
and the maker advises to shoot grease into them, regULarLY...
the screws pass through this grease filled sealed chamber going both wayz...
no dust, no dirt on the threads that i can see.
cheers
2air'
03-22-2010, 05:31 PM
#24
1993 34' Excella
Estancia
, New Mexico
Originally Posted by Mikethefixit
Malcom
I'm sorry,I sometimes forget my age. Years ago,cars came without starters.So we cranked.
Please go to the Sears website find tools and enter Model # 44271 and thats a 3/8's drive speed wrench. Its just a little crank that you can use a socket on to speed the loosing or tightening of nuts and bolts by hand without any power source except YOU.
I have several,they come is darned handy.
I generally don't tolerate little cranks very well, they remind me of my 1st grade teacher. I also use a Sears speed wrench but it's 1/2". The handles have bearings which make turning almost a sexual experience.
I used to poo-poo the sissies who used an electric tongue jack and could not get it up on their own until I got one.
Maybe before you go electric take a hit of Viagra.
03-22-2010, 06:01 PM
#25
1978 31' Excella 500
Venice
A good lubricant for areas with a lot of contamination like the stabilizer jack screw is spray graphite available from auto parts stores. It has an alcohol vehicle which evaporates quickly leaving a nice even coat of graphite which will not attract or hold dirt.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
03-22-2010, 06:26 PM
#26
Naysayer
1968 24' Tradewind
Russellville
, earth
The "new" ones I just installed have gobs of grease on them. Wonder if I ought to figure out a way to remove it and replace it with graphite.
03-22-2010, 06:44 PM
#27
_
ya might wanna check the manufacturers maintenance info FIRST...
not that they know or have any vested interest in this stuff.
while graphite in a spray/liquid vehicle is a FINE lubricant...
the solvents will make MUCK of the already greased parts internally...
grease contaminated with solvents is evil.
cheers
2air'
03-22-2010, 07:03 PM
#28
1993 34' Excella
Estancia
, New Mexico
cheers
2air'
Speaking of the BALs on my 71 neither the AS service manual or owners manual says jack.
03-22-2010, 07:08 PM
#29
on the hunt
riverton
, Kansas
sorry i would lube them with what every you like, just so you don't have metal on metal.
03-22-2010, 07:36 PM
#30
Maniacal Engineer
Lopez Island
For applications like this, I find the dry-style spray-on motorcycle chain lubes to be near perfect; they don't attract dust once dry (a few minutes) and contain molybdenum disulfide, which is a good extreme pressure lube.
Prevents rust, too.... this stuff also works nicely in keeping the various moving parts in Airstream window latches, etc, working smoothly.
- Bart
