Old 11-11-2014, 02:16 AM   #1
benicia , California
Do you use stackable leveling blocks or 2x10s under the trailer's jack?
I've seen pics of leveling blocks under the feet of the trailer but what do people use under the front jack? Do you bring the jack down pretty low or do you use multiple blocks or wood rather than crank the jack down?
cantdrv55 is offline   Reply With Quote
Old 11-11-2014, 02:33 AM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I'd rather not extend any of them fully , but use short pieces of wood cut from 2x10x16 pressure treat used under tires (Michelin recommends wood under tires no matter the surface). I also use a device which allows the tongue to be shifted from side to side.
I used to use plastic, but became disappointed in them. The wood, however, has a real weight penalty.
Old 11-11-2014, 03:46 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
We use a cast aluminum jack stand under the tongue jack or a flat aluminum diamond plate in the front, whenever we plug into electric. Too many sites have poor grounds. Potential risk of electrocution.
Wood is the cheapest leveling boards for under the wheels for longer stays. Stabilizers do not usually get boards or plastic. Battery powered drill gets them down and up fast, no need for boards.
Old 11-11-2014, 05:15 AM   #4
dznf0g's Avatar
Oswego , Illinois
I use jack foot unless additional height is needed or there is soft ground. Then I use lego blocks.
-Rich-
Old 11-11-2014, 05:37 AM   #5
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Under the wheels I use 4' 2x12 pressure treated, it's much easier to hit a 12" than 8" or 10". Under the tongue jack I use cut pieces, 6" long of 4"x4" pieces of wolmanized woood. I stack them in twos, then the next row if I need it in the opposite direction and so on. I've had to use as many as four rows, as I don't like to extend the tongue too far.
I know the 2"x12"x4' are heavy, but I figure it's simply part of my workout routine.
Safe Travels.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 11-11-2014, 07:30 AM   #6
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
I have been using a rubber stall Matt for horses, made from recycled tires.
It comes in a large sheet 4'X5' and is 3/4" thick, cut up into 8"X10" pcs. 1 sheet made 36 pcs. More than enough for most any leveling. They seem to hold up well although they are heavy, but the cost at about $.50 each and the fact that they are recycled well it's a done deal. I use an old milk crate to store then in the truck, I do not take all of them just about 15 pcs. More or less.
indy is offline   Reply With Quote
Old 11-11-2014, 07:33 AM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use either leveling blocks or wood cut offs as required. Depends on the angle of the pad.
MICHAEL
Old 11-11-2014, 07:51 AM   #8
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
I use Legos everywhere: under the tongue jack, the stabilizers and, as needed for leveling, the wheels. After trying wood first, the weight penalty and messiness was more than I wanted to handle.
Rocinante is our 2014 International Signature 27FB
Old 11-11-2014, 08:15 AM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I used to use all wood, but weight of the wood and the space it took up made me change. Now I use a combination of wood, plastic, and aluminum jack stands. I carry a set of plastic leveling blocks, a dozen 2x6 and 2x8 wood blocks. I also have a wedge built out of 2x wood that I use for driving the trailer onto if I need to change a tire. Occasionally I have used that wedge for leveling on a very un-level parking spot in the mountains. (each situation dictates which I use)
I got rid of most of the pressure treated wood and replaced with lighter untreated.
Alan
Old 11-11-2014, 08:28 AM   #10
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We use the Orange Lego Blocks for side-to-side leveling of the Airstream. Under the tongue jack we use a piece of treated 2x12 with a metal "tongue twister" that allows side-to-side movement of the hitch for hooking-up.
We like the Legos much better than lumber for leveling. The Legos are much lighter and versatile. On tandem axle trailers, the Legos can easily be made into a ramp to change a tire.We have done this on the road anumber of times. We used our Legos just a couple of days ago to mount our new 16" wheels and tires.
We carry three sets of the orange Legos. They weigh about as much as one or two pieces of treated lumber.We also carry four Lego caps or half height pieces.
Brian
SuEllyn & Brian McCabe
Old 11-11-2014, 08:34 AM   #11
Great advice everyone. Thank you!
Old 11-11-2014, 08:51 AM   #12
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I use cedar boards run through the table saw for a couple of kerfs on one side to stabilize them from warping for leveling and under the jack when needed. They're light and easy to use.
Doug and Cheryl
Old 11-11-2014, 08:52 AM   #13
daveswenson's Avatar
2012 28' International
Issaquah , Washington
I have one of these. Much easier than blocks.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 11-11-2014, 09:02 AM   #14
dkottum's Avatar
Dave, I like the simple operation of the Flip Jack but am wondering if it would fit inside the yoke of our ProPride hitch when up. Anyone tried it?
Doug and Cheryl
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
What to use as leveling blocks flint Jacks, Stabilizers, Lifting and Leveling 34 06-25-2012 07:49 AM
Alternative to leveling blocks tschat Jacks, Stabilizers, Lifting and Leveling 18 06-30-2011 07:54 AM
"Lego" leveling blocks--bad experience! Kistler Jacks, Stabilizers, Lifting and Leveling 9 08-28-2003 05:42 AM
