Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 11-11-2014, 03:36 PM   #21
extiger's Avatar
2011 30' Classic
Kingwood , Texas
I have a tong twister I use on the front jack. I have 2 2X4 cut a little longer than the tong twister and use them as needed. If I need more then 2, out come the lego blocks. I recently purchased the Andersen levelers for side to side and am extremely pleased with them. I used to carry 3 sets of legos, but now down to 2 sets. Like others have said, on ground I use at least one lego to spread the load. If a hard surface typically not unless it his a long stretch for the stabilizers. Cordless drill speeds up the stabilizer process.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 11-11-2014, 03:44 PM   #22
daveswenson's Avatar
2012 28' International
Olympia , Washington
Originally Posted by dkottum View Post
Dave, I like the simple operation of the Flip Jack but am wondering if it would fit inside the yoke of our ProPride hitch when up. Anyone tried it?
It extends about 4 inches back from the jack.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 11-11-2014, 04:09 PM   #23
1987 25' Sovereign
Aurora , Illinois
I finally got tired of replacing cracked chunks of 2X dimensional lumber. A trip to the lumber yard for a 12 FT micro lam (engineered laminated lumber), cut into 1 FT lengths has eliminated all splitting. A combination of lumber and legos satisfies all my leveling issues.
BillB54
billb54 is offline   Reply With Quote
Old 11-12-2014, 03:25 PM   #24
Nomad518's Avatar
2001 25' Safari
Ridgefield , Washington
I used to use wood, but now I use the plastic interlocking "Lego" blocks all around. I did find a great use for the wood though...firewood kindling.
Nomad518 is offline   Reply With Quote
Old 11-12-2014, 04:56 PM   #25
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We use a 7" cast aluminum jack stand...love it. They are also available in 4" ... made by a family in Indiana. I have ordering info if anyone is interested in them... PM me.
Name:	Cast Aluminum Jack Stands.png
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 11-12-2014, 05:46 PM   #26
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
We use the 4" version of this for our jack stand. Love it!
We also use the Andersen funky levelers for leveling, the Fastway OneStep tandem wheel chock for chocking and our factory installed stabilizers for stabilizing. :-)
Old 11-17-2014, 11:50 PM   #27
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Mjolnir doing the big float
Edit,,, cant paste.
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-18-2014, 10:57 AM   #28
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
+1 tbrich - jack stands can also be purchased at JC.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Old 11-18-2014, 11:43 AM   #29
webspinner's Avatar
Menlo Park , California
We use wood. We put a 4x4 on its side under the jack, plus enough 2x lumber to level if the front is on the low side of the site.
We have several lengths of 2x lumber on hand for leveling the low side of the wheels. Once, we put a 2x8 (2x6?) across the top of two rocks and parked the wheels on the "bridge" to level the trailer on a fairly steep side hill.
We keep four 3/8 plywood pads for each stabilizer. Our '71 has small feet on the bottom of the stabilizers and the wood helps on soft asphalt or damp ground.
Barbie
Our travel and renovation blog: https://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 11-19-2014, 09:44 PM   #30
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I have been parked where there was a huge slope and the shim capability was good.
The plastic I have come to detest as they will allow things to 'slide'... which can be a good feature... but, not when you want stability... important on the tongue jack...
So, a rule of thumb... I put a 3/4 plywood 'base' to spread the 'load' and keep rocks from damaging the underside of the plastic legos... It is amazing how much easier the Airstream tires seem to 'climb' the wooden blocks... without 'skidding' the plastic blocks which can be a nuisance when trying to set multiple under our 3 axle dainty AS.
If you get some 'sliding' of the wood sheets, a couple of flat head sheet metal screws, one on each corner, will keep things from sliding. Also, you can cut a 45 degree on the leading edge of the board and line them up for a 'ramp'..
Also, the 'stabilizers' tend to move a bit on the plastic legos...so the camper rocks more on them than on a wood base.
Sometimes 'wood' is the best solution for the problem..... depends on your use of your AS.... enjoy.
Channing
WBCCI# 30676
Old 11-21-2014, 01:47 PM   #31
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Originally Posted by Jim Flower View Post
I use Legos as required for levelling side to side and sometimes front to back but I always maintain a non insulated earth connection on at least one of the contact points. So even at an overnight boon dock spot, like Walmart, I will put the jack down. Jim
I have just read that this is a bad practice. I googled "grounding trailers from lightening". Don't do what I do. I wonder how many other things I do that don't work? Now I've got me nervous. Jim
Jim Flower is offline   Reply With Quote
Old 11-21-2014, 01:48 PM   #32
Jim Flower's Avatar
1997 25' Safari
I am referring to the metal ground, not the Legos. Jim
Old 11-21-2014, 02:11 PM   #33
1976 31' Sovereign
Oswego , Illinois
I have aluminum jack stand posted by TBRich that I pur. in 1976 I only use 2/ lumber painted blue so when muddy or need cleaning simple hose off nice & clean, long for tandem wheels to level under ea. stabilizer & if have to get jack stand higher stack 2/ under stand, only had 1 leveling board slip since 1962
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
What to use as leveling blocks flint Jacks, Stabilizers, Lifting and Leveling 34 06-25-2012 07:49 AM
Alternative to leveling blocks tschat Jacks, Stabilizers, Lifting and Leveling 18 06-30-2011 07:54 AM
"Lego" leveling blocks--bad experience! Kistler Jacks, Stabilizers, Lifting and Leveling 9 08-28-2003 05:42 AM
