Old 04-29-2016, 10:14 AM   #15
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Ok a different twist.
I don't jack it up off of the ground but I do take a bunch of weight off of the axles if it's going to sit for a few months. I use pickup truck jacks (the ones that come with a pickup to change tire) and lift it a bit. Tires stay on ground but lots of weight comes off the axles.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 04-29-2016, 10:30 AM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
I think the torsion axles and radial tires need exercise more than jacked up and left static, so if it sits for a long period we hitch up and take it for a drive.
Doug and Cheryl
Old 04-29-2016, 11:09 AM   #17
Watertown , Massachusetts
Thanks everyone!
Moving it every month or so sounds good, but it's kind of difficult to do sometimes, like the year we had 109 inches of snow in 3 weeks! That year (winter of 2014-2015) I was mostly worried that the roof would cave it!
I'm thinking that checking the tire pressure every so often, when possible, is probably our best bet.
One funny side story - during that year with all the snow, the snow was piled up above the bottom of the trailer. The local rabbits realized that there was a big open space below and created snow slides to get under the trailer and out again. I was expecting a lot of bunny "presents" in the spring, but apparently they didn't actually live down there because they left nothing behind.
sallye is offline   Reply With Quote
Old 04-29-2016, 11:48 AM   #18
JaynEss's Avatar
1994 21' Sovereign
The high country. Black Mountain range. , North Carolina
No.
WBCCI 28499
"Not all those who wander are lost"
J.R.R. Tolkien
JaynEss is offline   Reply With Quote
Old 04-29-2016, 11:54 AM   #19
BigButtUgly's Avatar
1958 22' Caravanner
not shared , Nebraska
sallye: Can't be of much help to you because I now have independent suspension with twin air bags so I lower my 1958 Caravanner to the ground whenever parked. Keeps weight off the tires. However, if I had any design of the Airstream antiquated axles I'd jack up the rig to keep weight off the tires and cover them. I put a small board held with a concrete block to cover the small remainder of my tires showing. My theory of no or minimal weight on tires prevents flat spots. If you should have to use your rig in winter it takes a while to reshape your tires, not so long in warmer weather however.
BigButtUgly is offline   Reply With Quote
Old 04-29-2016, 02:53 PM   #20
Anna Maria , Florida
Originally Posted by OTRA15 View Post
It is not necessary for your FC20 at all IMO, despite recent suggestions to the contrary for much larger and heavier trailers, by an owner who understands the intricacies and structure of Airstream suspensions, and who is able to fashion non-standard support on his own IMO.
Just move the trailer every month or so a few feet back and forth, in order to avoid theoretical flat spots on the tires.
Nice choice of trailer by the way, and welcome to the forum!
Cheers,
Peter
PS your water tank and holding tanks will be empty, and the trailer also lightened up by removing heavy canned goods, etc., so the loads on the single axle will be reduced
When not traveling, every thirty days I jack up one side at a time and rotate the wheels to the opposite side that it was sitting on. I also inflate the tires by 20% per manufacturers suggestion. I wash it at the same time so its a monthly chore. Of course I couldn't wash it if we were living up north in winter.
franklyfrank is offline   Reply With Quote
Old 04-29-2016, 02:59 PM   #21
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
My father and mother had a 1972 30', had it for twenty years or so, traveled about 200,000 miles, trailer sat for about six months every year. Never jacked up, no axles replaced etc no issues at all.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-29-2016, 03:51 PM   #22
CRH
1995 25' Excella
xxxxx , xxxxxx
Not counting the AS, I have close to 30 tires on the ground that don't get moved for 30+ days at a time. I have never imagined jacking anything up and spinning them 180 degrees. Never done it. Never will....never had a flat spot.
CRH is offline   Reply With Quote
Old 04-29-2016, 04:40 PM   #23
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
TETO.....
“Side effects from the Network News Broadcast?…ask your Doctor." 🤪
RLC
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 04-29-2016, 04:49 PM   #24
1973 31' Sovereign
Middletown , California
Yes, usually jack the tires off the ground when I expect to stay for a long time. I thought that dirt rotting tires was an old wives tale until I lived in a spot where the dirt was red clay with decomposing shale mixed in. I think I was there about three years and all 4 tires had rotten spots. The dirt on the tires and where they sat had turned sort of blue so something leached out of the rubber. I don't know how common this is, probably pretty rare. Even on that type of dirt might have been OK for a few months.
ijustlee is offline   Reply With Quote
Old 04-29-2016, 04:51 PM   #25
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
The answer is no - but having said that - I do remove accumulations of snow from the roof - not worried about the axles at all - but in this part of the world I don't like the weight on the roof .....
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 04-29-2016, 05:04 PM   #26
1966 24' Tradewind
2005 22' Safari
Bastrop , Texas
Our Safari lives in an enclosed barn with no windows or skylights with the the Michelin tires off the ground , with the front being supported with the tongue jack and the rest of the weight resting on automotive jack stands .
The lifting at the rear of the trailer is done with a floor jack under the rear skid bars one side at a time . This would not be a recommended procedure on most AS trailers as the frame is very weak . So weak that I was forced to design , fabricate and install an inverted truss system to the entire length of the frame allowing the enactment of the jacking procedure mentioned above.
This is done upon arrival at home from any outing and remains in this state until the next trip . My feeble mind reasons that while on the tires and in motion 100 % of all force is being used to force the hubs upward and twisting the rubber in the axle tubes in that direction with any hardening of the rubber over time in this upward position , so my feeble mind tells me that if the rubber is going to eventually harden up that it should harden up in the wheels off the ground position instead of gradually lowering the trailer closer to the ground while towing .
These are simply my thoughts on the subject , backed up by nothing more than decades of dealing with all things mechanical.
Have Fun !
dannydimitt is offline   Reply With Quote
Old 04-29-2016, 10:39 PM   #27
2004 22' Safari
Albuquerque , New Mexico
These won't work on a square torflex axle. A torflex axle can only be jacked up on the steel flange, never the tube as this effects the axle alignment.
Can you explain this? The steel flange an never the tube?
Silver.Sanctuary is offline   Reply With Quote
Old 04-29-2016, 10:42 PM   #28
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
The problem I would have with jacking it up in the wintertime is it prevents me from going camping during the wintertime.
:-P
Ian
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Do you take your flatscreen tv out in winter?? LyleRussell Winterizing, Storage, Carports & Covers 17 10-31-2015 11:09 AM
What would you do different if you were placing your concrete your pad again? dznf0g Winterizing, Storage, Carports & Covers 57 06-10-2015 10:27 AM
What do you do with your Hensley during the winter? dmcummins Hitches, Couplers & Balls 7 01-11-2011 07:12 PM
Winter? What winter??? Pahaska Off Topic Forum 21 01-06-2006 10:17 AM
Poll : What is your favorite ALARM when you're not in your A/S ? brunoffrance On The Road... 6 06-28-2003 05:34 AM
