Old 08-09-2005, 01:24 PM   #1
1978 25' Tradewind
Roseland , Florida
dangerous tongue jack
Hi,
I recently purchased a '78 Landyacht-Tradewind 25' trailer and have only towed it a couple of times. It has a 12volt tongue jack, which is great, but when I am towing it the shaft spins and hits the pavement. I was able to spin it back in and make it to where I'm going, but I am about to embark on a major trip and don't want to have this to worry about. I looked in the manual and all mine has is a blowup of parts, and it doesn't look like I'm missing anything. Hopefully this is a simple thing, I look forward to all feedback.
Eric
Eric, Tina and Kierstin Hedin
'78 Tradewind - Homeschooling RV Tech
kooblekidz is offline   Reply With Quote
Old 08-09-2005, 01:52 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Yikes!
I'd guess that the power switch has gone bad and that the bouncing when you are driving is completing the circuit in the downward direction. I'm not an electrician, so I'd take it in for service.
The only other thing that seems to make sense is that the gear may have stripped and it just slips down. Can you disconnect the power from it completely after you've cranked it up, then take it on a trip? Stop every 10 to 20 miles and see if it's still holding steady (measure the drop). If it holds, the problem is electrical, if it's still coming down, either a gear is stripped or someone over-lubricated it or super-lubricated it with something that reduces way too much friction.
Tin Lizzie
Old 08-09-2005, 02:18 PM   #3
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by kooblekidz
Hi,
Eric
Eric, Kevin Allen (overlander64) had a similar problem, his tongue jack started imitating a pogo stick while he was driving down the road. From his account, it really messed up his jack. it turned out to be electrical in nature, although by the time he got to where he could get it taken care of, the jack was pretty much toast. I have an electric tongue jack here I could let you have (cheap), if you want to make a detour. Maybe we can even get it installed before you continue your trip. PM me if you want directions to get here.
Good luck with it.
Old 08-09-2005, 09:32 PM   #4
Over59's Avatar
Putnam , Connecticut
Images: 37
Disconnect the jack when you travel. If there isn't an easy wire nut connection to undo and cap the hot end you could cut the power lead and put in a simple switch or use a wire nut to cap the hot when traveling and hook it up when you want to use it. If the thing moves when not wired then it's the jack. New Jack time.
Over59 is offline   Reply With Quote
Old 08-15-2005, 02:31 PM   #5
Overlander 63, My power jack just stripped the teeth on one gear yesterday. it is an original jack on 1970 overlander. If I can't find just the gear tomorrow I would like to buy your jack if it is still available. I will probably go to florida wednesday for a funeral but i will be in the northern gulf side (steinhatchee area). Let me know if it's available and how much.
Can anyone help me find the gear for this H&H power jack made in Battlecreek Michigan?
Thanks a bunch
Live and LET live
FrenchBern is offline   Reply With Quote
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 11:00 AM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 10:45 AM
New tongue layout FrankR Cleaning, Stripping & Polishing 0 03-07-2002 08:51 PM
