Old 04-28-2014, 08:59 PM   #1
2014 27' FB International
aviila beach , California
Corrosion Question
We just purchased a new 2014 International, upon arriving home (obviously too excited at the dealership to really check it out), we noticed that the frame, particularly the stabilizer jacks and some of the wire connections that attach to the exterior frame were pretty corroded; looks like they came off a unit ten years old or more. Is this normal?
Secondary question and totally unrelated. I work on computers virtually all day, but don't in any way count my self as a computer wiz. I'm new to these forums, but does anyone else find this less than intuitive? I would like to get involved in some up-to-date discussion, however found some information very old and outdated. How does one search for new and interesting information...
Moondoggie...
Moondoggie is offline   Reply With Quote
Old 04-28-2014, 09:07 PM   #2
2014 23' Flying Cloud
Reed Point , Montana
Hi Moon.......
Their are (pages) of information regarding corrosion "ad nauseum" : http://www.airforums.com/forums/f142...31743-135.html
All quite recent.......
P.S. Welcome to Airstreaming.......half the fun is maintaining the beast.
Bigskyrider8 is offline   Reply With Quote
Old 04-28-2014, 09:47 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
This corrosion probably means the trailer was exposed to a salty environment, such as when it was delivered to the dealer over salted winter roads, and was not thoroughly cleaned by the dealer when it arrived. What is the manufacture date?
Another possibility is exposure to the salt air near the coast, but not likely the dealer took it there.
Nonetheless get plenty of a corrosion treatment product, Boeshield T-9 is a good one for the underbody, and spray the underbody steel generously to stop the corrosion, and continue to use it in the future when it wears or washes off.
The aluminum shell exposed edges, rivets (actually the holes under the rivets), and exterior fittings such as light housings and hinges need ongoing protection as well. CorrosionX is a good product, maybe the best, for the shell.
The above-mentioned thread on corrosion will provide many good tips on caring for the trailer exterior.
Doug and Cheryl
Old 04-29-2014, 05:34 AM   #4
Gainesville , Florida
Take it back to the dealer for warranty work. Make a list. Do not go with an attitude, be nice. If not satisfied, then get an attitude. You seem to be handling this well. I would call the dealer, if this is not satisfactory then call Jackson center. Enjoy the trailer. Jim
Old 04-29-2014, 05:57 AM   #5
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Last year I noticed the same thing on a our 1 yr old trailer that really had not been used in its first year. The original owner did buy it at Colonial so there was some ocean air exposure while it sat on their lot, none after that. I sprayed everything with Boeshield and it has been fine since.
larry
lsbrodsky is offline   Reply With Quote
Old 04-29-2014, 08:48 PM   #6
Thanks, guess I'll just have to get out the ol' wire brush, some steel wool and Boeshield
Old 04-29-2014, 10:10 PM   #7
dkottum's Avatar
No wire brush or steel wool, unless you want to repaint it. The Boeshield applied from time to time, or as needed should neutralize the corrosion and protect the metal.
Or is this really, really bad corrosion? Hard to imagine.
Doug and Cheryl
Stainless steel corrosion Dave-O Stoves, Ovens & Microwaves 21 04-05-2014 06:30 PM
Newbee Clearcoat & Corrosion Question Ridgerunner3 Clearcoat, Exterior Paint & Trim 2 09-21-2011 08:19 AM
Galvanic corrosion question reggiemon Ribs, Skins & Rivets 4 04-11-2009 05:01 PM
interior wall corrosion? 60traveler Interior Restoration Forum 12 08-11-2003 12:42 PM
corrosion under lites Chas Ribs, Skins & Rivets 4 05-18-2003 08:57 AM
