Old 08-28-2007, 08:27 PM   #1
TankerIP's Avatar
2002 22' International
Confused on Jacking the 22'
I need to replace the tires on our "new to us" trailer. I wanted to take the tires off myself so that I would have the opportunity to inspect brakes, bearings etc. Now I don't know how to safely jack up this little trailer.
I've read several forum posts and my manual about jacking the Airstream. I've learned never to jack using the axel tubes. My manual says there is a welded jacking plate and decal rear of the tires. I've looked -- there is none.
The attached photos show some of the underside. Aft of the tires there is nothing but the c-frame and, as I've learned, a very vulnerable underbelly that is basically just the floor.
In the second picture I found a possible spot to jack which is basically the frame that is adjacent to and above the axel. Do you think this is solid enough to jack up the trailer there? Should I try to call the (1-880) Airstream number to get help?
ID:	44013   Click image for larger version
TankerIP is offline   Reply With Quote
Old 08-28-2007, 09:11 PM   #2
drag'nwagon's Avatar
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville , Michigan
Do not jack anywhere under the belly pan!!! Place a bottle jack under the axle mounting plates and lift there. This is the best place not to bend anything and will be an easy spot to lift. Please though SAFETY first, lift one side at a time and place chocks on the other side, also put a couple jack stands under the plate as well. We need you alive.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
drag'nwagon is offline   Reply With Quote
Old 08-28-2007, 09:36 PM   #3
TankerIP's Avatar
What is the axle mounting plate?
Thanks for the input. Now next question. What exactly is the axle mounting plate? See my attached photo. Should I try to put the bottle jack at point #2 in order to lift?
Old 08-28-2007, 09:40 PM   #4
1970 23' Safari
The axle mounting plate is the "plate" that the axles bolt to, it has the cut outs for the axle tube in it probably 3/16 to 1/4" thick.
Dave
TAC# MI-1
Old 08-28-2007, 09:52 PM   #5
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Originally Posted by TankerIP
Thanks for the input. Now next question. What exactly is the axle mounting plate? See my attached photo. Should I try to put the bottle jack at point #2 in order to lift? Thanks
Yes, point #2 would work as it is directly under the "C" channel frame rail. Your arrow points to the axle mounting bracket that is welded to the square axle tube. The axle mounting plate is directly behind (to the inside of) the axle mounting bracket; it is the vertical plate on the inside of your frame rails that the axle mounting bracket bolts to. Happy lifting!
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 08-28-2007, 10:13 PM   #6
_
look for the diamond shaped bit of skin....
http://www.airforums.com/forums/f457...eam-18435.html
cheers
2air'
Old 08-28-2007, 10:17 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I must not be understanding something about jacking up ASs...I have read as much as I can about this...(and I'm sure most are tired of talking about it)...but still I am confused...
I understand that the easiest way to take a tire off is to not use a jack at all, but to back one of the tandem tires onto riser blocks, thereby raising the tire that is to be removed...
But if that is not an option (as in having only one axel or needing to remove all the tires on one side at the same time) one should jack up the AS using the axel mounting plates (not the axel)...as opposed to what the AS manual says to use, that is, the jack points that are supposed to be labeled...which in our Bambi's case, is about 1/2 the way between the axel and the back bumper.
Why do so many say using the "AS sancntioned" jack points is less desireable? I don't mean to be contrary...I just want to understand.
Thanks for understanding,
TB
Old 08-28-2007, 10:25 PM   #8
_
Originally Posted by TBRich
...Why do so many say using the "AS sancntioned" jack points is less desireable?...
if they can raise a 34 at those points...
http://www.airforums.com/forums/428907-post42.html
you can raise bambi there.
cheers
2air'
Old 08-28-2007, 10:35 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
cheers
2air'
2air'...
I was hoping to hear from you on this... THANK YOU for your definitive resolution of this point in my head. The designated AS jack points it is!
I can sleep better tonight...finally...knowing the proper way to jack up the Bambi...
TB
Old 08-29-2007, 06:49 AM   #10
TankerIP's Avatar
There is no "diamond"
I looked for the "diamond" bit of skin behind the rear wheel and could not find it. Neither is there any decal or marking. As you can see in my original photo post (#1), The tank takes up most of the under belly space. The main frame "Girder" is covered by the tank. There's a cross "c" metal girder that's open for possible jacking, but it looks just too light weight. Anyone out there with a 22' constructed like mine?
Old 08-29-2007, 09:54 AM   #11
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Jack point on my AS
I have wondered about this too.... where to jack? See the attached photo. Do I place the jack under the "diamond?" Seems pretty obvious, but I want to know for sure. I have a hydraulic jack that I could use.
George
Name:	jack point sm..jpg
ghatfield is offline   Reply With Quote
Old 08-29-2007, 10:11 AM   #12
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Maybe you will get lucky.
On our old 79 Ambassador, I followed one of those stickers under the belly pan and punched a neat jack shaped circle thru the sheet metal. After patching, I only use the axel mounting plate between the wheels. It is a nice thick piece of structural steel.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 08-29-2007, 05:25 PM   #13
TankerIP's Avatar
What the Dealer Said
Well, I decided to go see the local Airstream Dealer (Austin/Buda Texas). Not the biggest in the world, but it's what we got. Although, I'm a used trailer owner, my trailer originated from this dealer. I talked to service guy. He said "Jack it up from the frame". My immediate question was "Where on the Frame?", He said: "Right there where the axle is. That's where we do it". Seemed like he meant the "knife edge" of the frame where the axle is mounted. I was worried that that place might not allow much stability for the jack. Kind of like, it might allow the unit to "wobble". I thought you needed a flat surface for the head of the jack to push on.
In any case, I guess I have enough guidance now to make a safe attempt to jack this l'il trailer. I will make sure it's well chocked. I will get a good assortment of jack stands available. I will get the hydraulic bottle jack from the garage and then start lifting.
ON A SEPARATE NOTE: Did anyone notice that I don't have any metal covering on the bottom of my trailer? I'm still trying to understand that. Maybe it was built that way? I'll need to start another thread to get some answers. Do I need that belly metal?
Old 08-29-2007, 05:50 PM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
We Agree
Our "63" 22' Safari shed it's wheels every Buffalo winter for 18 years, and I used that same point every year without a problem. Good heavy stands held up well with several coats of paint once in awhile.>>Not sure about the belly pan, but I don't recall seeing an A/S without one.
Name:	STREAM'N ON RT.66.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Jacking points on '77 27' International johnmw Jacks, Stabilizers, Lifting and Leveling 13 12-13-2002 12:05 AM
What is the MOST you have paid for an AIR STREAM part overlander Our Community 64 11-19-2002 05:15 PM
