Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 08-05-2007, 05:37 PM   #1
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
Can you get a manual crank head for a power jack?
Hi all,
Have an electric tongue jack that decided to go south. The hand cranker on the other trailer still works great. I'm wondering if I can buy a front crank adapter to sit on top of the electric jack if I remove the power head. That is, can I "rebuild" the electric jack as a manual unit? Or must I just buy a new manual jack?
I've had it with electric.
- Jim
JimGolden is offline   Reply With Quote
Old 08-05-2007, 05:55 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Jim, a manual jack will probably cost about the same as the bits and pieces you would need to retrofit your electric jack. New manual jacks are less than $30 at Northern Tool, and Tractor Supply.Bulldog Round Tube A-Frame Jack — 5000-Lb. Capacity | Trailer Jacks | Northern Tool + Equipment
Old 08-05-2007, 06:00 PM   #3
Jaxon
E Pluribus Aluminus
Jaxon's Avatar
Profile:  2005 30' Classic
We had the same thing happen to ours once just after driving up and backing the 'stream in. Took the electric head off and used the "supplied" hand crank that came with the Airstream (kind of wondered what that was for...!). Worked like a charm. The manufacturer sent me some parts to fix it after I contacted them but I was unable to do so - plastic parts-gears. Airstream intervened on my behalf and a new head was sent to me. Always nice to know it's there just in case.
Bill & Kim's Marvelous Adventure
with Catahoula Charlie
30' Classic
F250 Diesel
AIR 9218
Jaxon is offline   Reply With Quote
1977 Safari Manual RamblinRose General Interior Topics 2 04-17-2004 05:51 PM
voltage for electric jack maznblu Towing, Tow Vehicles & Hitches 3 04-16-2004 09:32 PM
Power Jack Problems Daniel Conroy Electrical - Systems, Generators, Batteries & Solar 4 04-15-2004 11:40 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 03:51 PM
