Old 08-05-2007, 04:37 PM   #1
JimGolden's Avatar
1977 31' Excella 500
Can you get a manual crank head for a power jack?
Hi all,
Have an electric tongue jack that decided to go south. The hand cranker on the other trailer still works great. I'm wondering if I can buy a front crank adapter to sit on top of the electric jack if I remove the power head. That is, can I "rebuild" the electric jack as a manual unit? Or must I just buy a new manual jack?
I've had it with electric.
- Jim
JimGolden is offline   Reply With Quote
Old 08-05-2007, 04:55 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Jim, a manual jack will probably cost about the same as the bits and pieces you would need to retrofit your electric jack. New manual jacks are less than $30 at Northern Tool, and Tractor Supply.Bulldog Round Tube A-Frame Jack — 5000-Lb. Capacity | Trailer Jacks | Northern Tool + Equipment
Old 08-05-2007, 05:00 PM   #3
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
We had the same thing happen to ours once just after driving up and backing the 'stream in. Took the electric head off and used the "supplied" hand crank that came with the Airstream (kind of wondered what that was for...!). Worked like a charm. The manufacturer sent me some parts to fix it after I contacted them but I was unable to do so - plastic parts-gears. Airstream intervened on my behalf and a new head was sent to me. Always nice to know it's there just in case.
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
1977 Safari Manual RamblinRose General Interior Topics 2 04-17-2004 04:51 PM
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
Power Jack Problems Daniel Conroy Electrical - Systems, Generators, Batteries & Solar 4 04-15-2004 10:40 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Battery drained while on shore power 68International Electrical - Systems, Generators, Batteries & Solar 4 07-15-2002 02:51 PM
