Old 07-28-2011, 03:56 PM   #1
1969 27' Overlander
duluth , Minnesota
Can I jack up the Land Yacht on the rear bumper?
So im trying to replace the floor panel of the rear storage compartment inside the rear bumper. To get the old floor panel out i need to raise my yacht to drill out the old rivets. Can i place the front on jack stands and jack it up under the rear bumper? I dont want to bend or break anything! Whats the best way to go about this? Thanks everyone! And yes you guessed it im a newb.
attorv is offline   Reply With Quote
Old 07-28-2011, 03:58 PM   #2
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard
No!!!
FRAME
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 07-28-2011, 06:00 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Welcome to the forums!
No!
You can jack up your Airstream at the mounting plates for the axles. If you you use the bumper it could cause frame and skin damage. Hope this helps.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 07-28-2011, 06:26 PM   #4
I did use the front section of the frame extension that supports the bumper to lift our 63 Safari. (no frame rot)
You can see them on this side view of an Overlander. Maybe other owners will comment.
PFC
RLC
Old 07-28-2011, 07:41 PM   #5
1967 22' Safari
1960 Caravel
Images: 8
I really can't see the jack placement from your pic...
Do you have a larger pic?
Did you lift the Airstream off the ground from these points?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 07-28-2011, 10:57 PM   #6
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Level ground - no complications?
You can only brace - and lift the sag out to level the ladder frame points once you lift the frame from the correct points. Its a C-channel and will collapse, bend, distort, stretch. There are dozens of posts here on the subject - the search function is your best bet to get the background to ask the right questions - here's two I've contributed to. Oh yeah, the risk is all you - don't even trust we can see how and what from our PC keyboards
http://www.airforums.com/forums/f175...ent-36822.html
http://www.airforums.com/forums/f457...tml#post419247
The vertical steel sheet that the axles mount to is the only place to safely lift the trailer from. There is room for 6x6 wood blocks to crib up the jack, and you will need a block of wood with the grain oriented across the plate steel length to keep it from splitting from the knife-edge effect, and you will need blocks to chock it up besides the jack blocks. You can't lift much at one time, a 4x4 height at a time then safely block it up, then go to the other side... blah blah.
Old 07-28-2011, 11:14 PM   #7
1985 31' Excella
Fresno , Texas
Back it up on some 2x10 pieces
Wsmith is offline   Reply With Quote
Old 07-29-2011, 12:25 PM   #8
Wabbiteer's Avatar
1972 29' Ambassador
Wsmith gets the golden ring - if you don't " have " to lift the trailer 16 or 24 inches plus, there is always building up ramps out layers of 2x10 or 2x12 lumber or a combination of block and lumber...
Rear bumper repair - 2000 classic grumpy Bumpers & Bumper Storage 4 04-03-2012 04:19 AM
where to get a new rear bumper shroud? IPM Classic Motorhomes 9 07-07-2011 02:44 PM
Rear bumper / hose fittings Hoosierdaddy Bumpers & Bumper Storage 1 07-04-2011 08:47 PM
'78 Argosy Minuet broken rear stabilizer jack ArgosyMinuet All Argosy Trailers 2 06-20-2011 08:42 AM
Will gasket material seal the rear bumper storage? tvanwave Bumpers & Bumper Storage 0 01-31-2011 04:00 PM
