Old 06-07-2011, 03:33 PM   #1
1992 30' Land Yacht
Hamilton , Ontario
Can I add hydraulic fluid to jacks?
I have a 92 landyacht with automatic leveling jacks. Work well, but I do have one piston leaking and want to add fluid to the system. How do I do that? I have removed the cover to the motor but do not see a tank to add fluid.
thanks
peter
lululand is offline   Reply With Quote
Old 06-07-2011, 03:58 PM   #2
woodja's Avatar
1982 31' Airstream 310
Dayton , Tennessee
I'm sure you have a reservoir somewhere. On my '82 310 it's almost directly under the drivers seat (& close to the controls). It must hold several quarts & fills from the top where you can't possibly see what your doing. Follow your hoses & it'll surely be right there.
Pete
woodja is offline   Reply With Quote
Old 06-07-2011, 04:10 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Just make sure you check what type of oil it takes.
2004 Excursion 4x4
Old 06-07-2011, 05:28 PM   #4
lewster's Avatar
Naples, FL , Hood River, OR
thanks
peter
Peter,
If you have an HWH leveling system, there is a fluid (Dexron III or HWH premium hydraulic fluid) reservoir attached to the motor and pump. It is usually square in shape and will have a small filler cap on it. Your solenoids should also be mounted to a manifold on this same unit.
When you add fluid, be sure that all jacks are fully retracted, remove the cap (which doubles as a dip stick) and fill until the fluid reaches the bottom of the extension on the cap. You should be good to go then.
Old 06-08-2011, 08:39 AM   #5
1992 30' Land Yacht
Hamilton , Ontario
thanks to all. found it. filled it and working A-ok.
Peter
Old 06-08-2011, 03:47 PM   #6
Ottawa , ON
Peter
Peter,
Can you share with us where the fill point is, and whether or not you actually found the leak?
Dent repair using load jacks Splitrock Ribs, Skins & Rivets 8 04-30-2011 02:18 PM
Should I add wheels to the back bumper? Scott J-24 Towing, Tow Vehicles & Hitches 12 04-04-2011 07:40 PM
No Power to Hydraulic Jack cloudflyer Winterizing, Storage, Carports & Covers 3 03-31-2011 06:28 PM
Hydraulic leveling system. boatdoc Jacks, Stabilizers, Lifting and Leveling 18 02-08-2011 06:30 AM
