Old 03-03-2010, 12:37 PM   #1
1978 28' Ambassador
Savannah , Georgia
Can anyone ID this manual jack?
Found out that the '78 Ambassador came with an electric tongue jack, but it seems to have been replaced with the side crank manual one shown below. Can anyone direct me to the manufacturer and if it can be fixed. Handle just spins and does not engage teeth. Can not see an identification model number anywhere. Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 03-03-2010, 12:43 PM   #2
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Rather than try to find parts for an unknown jack that is in questionable condition, I suggest calling a local heavy-duty trailer parts supplier and just getting a new one. I just bought a new electric jack last year for under $200.00. A manual one should be less than $100.00.
Yours should be an easy swap as it looks like the previous owner bolted it on rather than welding it!
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 03-03-2010, 12:51 PM   #3
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I agree. I have electric jacks on both trailers. Wouldn't have it any other way. Why fight the crank when you can push the button? If manual cranks were the hot set-up, they would still be using them on new Airstreams.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 03-03-2010, 01:04 PM   #4
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Jack
Go to Tractor Supply or Harbor Freight they both carry manual jacks or your local RV Dealer or Online Rv Suppliers. Mine also had been replaced by one of the former po's. I have not had a problem with my manual jack. When I find I cannot crank anymore its possibly time to sell or spring for Electric.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 03-03-2010, 02:09 PM   #5
1978 28' Ambassador
Savannah , Georgia
Thanks for all your comments. Think it is wise to just replace jack instead of trying to fix. Problem is finding a side crank jack on the shelf. Can order a 2,000 lb jack on that bolts on for $45. A wise investment. Need to crank to get at least a little exercise! Jack
Old 03-03-2010, 02:43 PM   #6
kevin242's Avatar
1977 25' Tradewind
I don't know pricing, but a good quality jack rated for a higher weight capacity might have a better gear ratio for ease of cranking and might last longer. Sometimes saving $20.00 or more just isn't worth it... especially if you get a "made in China" special ... don't buy without looking around and asking some questions about specifications.
Old 03-04-2010, 05:37 AM   #7
1978 28' Ambassador
Savannah , Georgia
The Ambassador weighs 5,500lbs, hitch weight is 575lbs. I ordered a 2,000lb side winder triangle base jack from Atwood. As a side note I went and tinkered with old jack. Cleared out the old dried grease. Found that one tooth of the top gear/cog was missing. May have done that by trying to crank with the gears frozen in old grease or it may have already been broken/sheared. In the process, the jack dropped 2 inches and scared the hell out of me. Still on jack stands. Learned a valuable lesson. Heading back out there to place tongue on cinder blocks to secure until new jack arrives. This lesson will be used when investigating all other operations of the trailer. Jack
Old 03-05-2010, 06:19 AM   #8
1978 28' Ambassador
Savannah , Georgia
What the heck is this "bolt"?
New jack may arrive Monday. Decided to remove old jack and clean up skid foot. The two back bolts came out after penetrating oil. What the heck is the front screw/bolt/ thingie? Backed off the nut and the entire bolt started unscrewing and then it stopped. I assume it serves a purpose other than holding the break-a-way control. Plan to use vise grips to remove. Hope it does not have a nut on the other end. My big ole hand won't reach up inside the hitch plate. Where can I get a replacement bolt/thingie? Thanks. Jack
Old 03-05-2010, 10:47 AM   #9
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
It might be the other end of your brake kill switch.
In that the cable ran from the switch looped to the TV ball and back to this bolt.
Just a thought.
Action
Old 03-08-2010, 05:05 AM   #10
1978 28' Ambassador
Savannah , Georgia
Finally removed the front mystery bolt. Haven't been able to determine it's function or a replacement. Decided to get a 3/8" bolt, cut off the hexhead and grind it smooth. Whether or not I ever need it, at least it will be there. Have been replacing most hardware with stainless steel. The threaded holes in the hitchplate are badly rusted so will retap the threads before installing new jack. Did I mention the jack stand foot was rusted/bonded to old jack? Got to take out some frustration separating the two.
Old 03-23-2010, 01:07 AM   #11
1972 31' Sovereign
Des Moines , Washington
Skamper1,
Just a note, stainless bolts are not as strong as grade 8! And they are more brittle.
Curt
2wheelin is offline   Reply With Quote
Does this jack have a manual override? NicheVintage Jacks, Stabilizers, Lifting and Leveling 2 01-16-2010 11:00 PM
Manual hitch jack hampstead38 Hitches, Couplers & Balls 17 10-23-2008 05:26 PM
manual (ratcheting) jack dolly? Jabba Jacks, Stabilizers, Lifting and Leveling 2 05-31-2008 10:55 AM
Manual Tongue Jack Failure Sugarfoot Jacks, Stabilizers, Lifting and Leveling 38 11-30-2006 07:09 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
