Old 04-12-2010, 06:40 AM   #1
2010 16' Sport
portland , Maine
Can a small Airstream be lifted?
Just purchased a Sport 16 and I drive lots of rough dirt roads. With 6 inches of ground clearance, I'm a little worried about bottoming out. Wondering if anyone has ever seen a lift kit on an airstream??? If so, any thoughts or suggestions on the best way to go about adding ground clearance would be appreciated. If I pursue this option, I'll post the full story. Thx in advance. Best. JD
sport 16 is offline   Reply With Quote
Old 04-12-2010, 08:01 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
I am confused.
Where are you measuring a 6 in. ground clearance? The frame appears to have standard clearance. Is it the axle beam itself you are referring to?
2004 Excursion 4x4
Old 04-12-2010, 08:14 AM   #3
2010 16' Sport
portland , Maine
the lowest point on the trailer (2 petcocks on rear tank) is 6 inches off the ground
Old 04-12-2010, 08:30 AM   #4
There are 2 ways to lift the trailer.
The first and easiest, is to change out the axle with one that has a greater starting angle. But, that will only give you maybe another 1 1/2 inches.
The second, is to remove the axle, pull some of the underbelly, remove the axle mounting plates, add a steel channel to the frame, of 4, 5 or even 6 inches, weld new axle mounting plates to the new part of the frame, and then remount the axle.
Air shocks "WILL NOT" work.
Increasing the tire size, would add very little, but would cost probably more than it's worth.
Old 04-12-2010, 08:35 AM   #5
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
You would need to replace the axle. One that has a different offset than your current one.
Michelle TAC MT-0
Sarah, Snowball
Old 04-12-2010, 11:27 AM   #6
HowieE's Avatar
Images: 12
Can you post a picture of these petcocks?
My first thought would be to reroute them further forward if their source allowed that. Remember the clearance is measured along a line from the bottom of the rear most tire to the bottom of the bumper. Anything above that line should be considered as clearing any road conditions.
If you can turn the source of the petcocks above that line and route them forward to a point that allows access and remains above that line you should be good.
2004 Excursion 4x4
Old 04-12-2010, 12:25 PM   #7
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I would opt for changing the axle for one with more starting angle. I did that with our Excella. It added more than 1 1/2 inches as the old axles were worn out, however it did put the trailer quite high. Wouldn't want it any higher.
A little more down angle may also be better for rough roads as it will be better "stepping over" bumps etc. Check out the down angle on off road vehicle trailing arms.
1 1/2 inches is really quite a lot when you see it, especially over the original height.
Adding to the frame is something that can not be undone easily, and would make the trailer very high.
Just my 2 cents.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 04-12-2010, 12:50 PM   #8
_
many threads, few easy solutions and only marginal gains for a SHORT trailer.
a single axle unit RAISED will be that much less stable on the roadways and highway speeds...
http://www.airforums.com/forums/f345...ads-58054.html
http://www.airforums.com/forums/f437...oud-26588.html
http://www.airforums.com/forums/f437...ight-5087.html
http://www.airforums.com/forums/f44/...ting-8529.html
http://www.airforums.com/forums/f437...nce-43275.html
http://www.airforums.com/forums/f437...lla-27051.html
http://www.airforums.com/forums/f48/...nce-25098.html
http://www.airforums.com/forums/f42/...ams-22102.html
cheers
2air'
Old 04-12-2010, 01:21 PM   #9
2008 16' Safari
Destrehan , Louisiana
I've got the same trailer and the same problem. I have not bottomed out yet, but I do worry about it. I was wondering if going to a 15" wheel would work? Is there enough clearance in the wheel well to do this. Also, would a 15" rim even bolt up to this axel?
dlb435 is offline   Reply With Quote
Old 04-12-2010, 02:07 PM   #10
2007 27' Safari FB SE
McKinney , Texas
If you can't lift it look at armoring it to glide over those cantankerous obstacles. Lower COG is always better. A trailing arm suspension like used on most Adventure Trailers could be done and work quite well on and off road. It could be raised for rougher roads and lowered for highway travels. Check out Adventure Trailers website. The ir most current set-up uses a triangulated trailing arm with and airbag as the actual spring (in place of the torsion spring on the trailer currently) and then a shock absorber.
I am certain this will ruffle some feathers, but it is an option.
Krazyjohnny is offline   Reply With Quote
Old 04-12-2010, 08:01 PM   #11
2007 25' Safari FB SE
Suburbia , Sunny So Cal
I have the same problem and had the same questions and got the same answers and one more that has worked on dirt roads all over the Mojave and Sonoran deserts and Oregon forrest roads.
I was told to do what Wally did crossing Africa. Slow down. Seems like a smart aleck statement but it has worked for several years now.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 04-12-2010, 08:07 PM   #12
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Bingo !
I've taken my Caravel down dirt and gravel roads with some rather large rocks in the way. Stock height. No problems.
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 04-12-2010, 08:25 PM   #13
Maniacal Engineer
barts's Avatar
Menlo Park , California
The simplest solution is indeed to slow down... but since inattention can strike, how about small skid plates that protects the vulnerable areas? Having a pet cock as your first point of contact seems almost assured of causing problems on rougher tracks, even w/ a careful driver.
A bit of 1/4" 6061 w/ a gentle approach ramp would help a lot.
Alternatively, redesigning the petcocks for more ground clearance might also be a reasonable solution...
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
The Can Can Can travelfables Member Introductions 3 02-01-2014 01:56 PM
Towing /w Truck Lifted oomph Hitches, Couplers & Balls 6 11-10-2011 09:45 AM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
Lifted AS - SNAP CRACKLE POP? netlace General Repair Forum 14 07-02-2009 02:01 PM
