Old 06-19-2006, 07:03 PM   #15
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Gen Disarray
I think I must be the last guy in the world useing screw jacks to stabilize my trailer.
Rodney, you are the next -to-last guy, at least until we get the last two BAL stabilizers installed under the front of our coach.
Old 06-19-2006, 07:11 PM   #16
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Yes you use the blocks under the wheels to level from side to side. Some people just block one wheel on a 4 wheel trailer. Not recommended for long stays. Leveling from front to back is done by the tongue jack. Then you stick stabilizing jack stands under the rear bumper in the old ones to make it so it does not move as much and crank up the tonque jack a bit more to put a load on the jack stands. originally they used screw jack stands in the back with a screw driver acting as a cross tee to put some load on the stands. They also sell special sissors jacks now intended for trailers and motorhomes. Painted boards about 15 inches long witn 45 degree bevels on the ends also work instead of buying the plastic ones. Have a selection of 1x 6 and 2x 6 available for varing campsites. 15 inch ones fit between the dual wheels so you can get both tires up on boards.
Old 06-20-2006, 09:59 AM   #17
spinyman's Avatar
2005 19' International CCD
VALLEY CENTER , California
Blocks?
Question. How do you keep the trailer from rolling off the blocks? I have a single axle trailer.
spinyman is offline   Reply With Quote
Old 06-20-2006, 10:46 AM   #18
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Get these:
Found these at the Lynx website.
I have dual axels, so I use the expanding clamp that goes between the tires.
Richard
Old 06-20-2006, 11:32 AM   #19
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Not next to last
Rodney, do not fear... Colin Hyde, my fellow host on the VAP, is still using screw jacks too on his 59 Ambassador....work like a charm on the rear bumper. They look like the little screw type scissor jack out of a VW or Subaru. Small, and do the trick. Like WAHOONC stated, be careful placing them under the trailer or you will damage the belly pan... and again, these are not for JACKING the trailer, just stabilizing it. Trying to use these to jack the trailer to level it will only twist / torgue the frame and cause other problems you DO NOT want. Only way to level is with boards, the leveling blocks, or find a nice level spot to park. The main reason for leveling, beside being comfortable, is for the RV fridge to work, they must be level from front to rear (not so important side to side) for the fridge to perform optimally.
Good luck,
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 06-20-2006, 12:10 PM   #20
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Nope, we still use the oldie but goodies...
We also use the old screw stands for stablizing...I like the vintage look to them. At the end of this post, is a picture of some stablizing jacks courtesy of ebay...mine are just like these. The screws come out and they stack together when not in use.
We have the yellow lego-style leveling blocks, sometimes I've put one under each of the stabilizing jacks if the site is really unlevel, soft or muddy. I like them better than wood because they can be hosed off and dry fast because they are plastic, they are lighter than wood and they lock together to create different heights whereas wood just stacks. We level one side and chock the other.
For awhile, we used a BAL jack for single axle trailers which was really cool, chocked & leveled all at once, but it was too bulky to lug around.
Shari
Old 06-24-2006, 03:39 PM   #21
1970 31' Sovereign
palm springs , California
Thank You! Thank You! Thank You All!!
happydaze is offline   Reply With Quote
Old 06-24-2006, 04:04 PM   #22
Killo1's Avatar
2005 22' Safari
Santa Ana , California
Has anyone here ever put levelers, and not stabilizers on their AS?
Alan
2005 22ft Safari
2003 Chevrolet Suburban Z71 5.3l
"Life is like a box of chocolates..." Forrest Gump
Killo1 is offline   Reply With Quote
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
your tow rig john hd Off Topic Forum 25 01-14-2003 09:49 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
Trailer Friendly Camping California bkpine Our Community 31 08-19-2002 01:26 PM
