07-07-2016, 02:29 PM
1993 25' Excella
CLeveland
, Ohio
Camco Leveling Blocks
Does anyone use those yellow leveling blocks on their Airstreams or is just buying a 2 x 10 and cutting it up work just as well? Drawbacks? Thanks in advance.
07-07-2016, 02:47 PM
2011 23' FB Flying Cloud
2008 19' Safari SE
Brossard
, Quebec
Camco blocks
I just bought a kit at Wallmart, and they works great!
Takes less space to carry than wood blocks
Michel
07-07-2016, 02:50 PM
1976 31' Sovereign
Oswego
I use 2/8 blocks of varying lengths painted w/ust oleum blue that matches AS blue trim. The reason for painting is when get dirty or muddy just hose off, only draw back is they some times split, but def. less money than ugly yellow plastic blocks, also if mud is wet slide in grass or wipe with wet rag to remove most mud and don't have to put away nasty as yellow blocks not that easy to clean at campsite.
07-07-2016, 04:03 PM
2005 30' Classic
Burlington
, Ontario
I have used the Lynx levellers for years & like them.
Light weight, easily cleaned with a hose, and interlock nicely to make a solid pyramid when needed to raise one wheel on a dual axle trailer when you need to remove the adjacent wheel
Not very often I have been on a site where I need to use them to level the trailer side to side, but they do work fine for that too.
If I don't need them for other purposes I often use the under the stabilisers.
I believe mine are ten to the set and I carry two sets in the trailer.
They are usually available at Walmart for quite a bit less than RV dealers - esp. Camping World!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
07-07-2016, 04:16 PM
2008 19' Safari SE
Brossard
, Quebec
LYNX Levelers
Michel
I have to mention that I have 2 sets of LYNX Levelers in my trailer.
A must to have under the whells in boondoking.
Michel
07-07-2016, 04:57 PM
2014 25' Flying Cloud
Cuddebackville
, New York
I usually use wood blocks, but also carry the lynx. I use them as extras when needed and on the rare occasions that the ground is too slippery for the wood not to slide when driving up on it.
2019 Ford Expedition Platinum
07-07-2016, 06:11 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
We use Lynx blocks (we have 3 bags, do we win a prize?) instead of wood because they are lighter and pack away easily.
We also have the yellow Trailer Aid ramp in case of a bad tire.
We also have the Andersen levelers: https://www.andersenhitches.com/Prod...r-leveler.aspx
I guess we're boy scouts or something.
07-07-2016, 06:22 PM
2016 25' Flying Cloud
Louisville
, Kentucky
We switched to the Anderson levelers as well. They are a lot faster and infinitely adjustable (up to 4"). (I suppose if they are limited to 4" they could not be infinite.) :-)
I use the camco blocks to even out the differences in the stabilization jacks.
07-07-2016, 06:34 PM
2004 30' Classic Slideout
Fenton
, Missouri
The key with leveling blocks of any type is to make sure that the tire tread is fully supported by the block. Any situation where any of the tread is unsupported or where the tread is half on and half off a block puts stress on the belts that could lead to belt damage.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
07-12-2016, 08:43 AM
1993 25' Excella
CLeveland
, Ohio
Michel
Aren't those jacks for stabilizing only and not lifting to level?
07-12-2016, 09:43 AM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
I use the Lynx blocks too. They work well with the big spirit level; each line on the level means one block on the low side.
After you are level, then you use your stabilizing jacks to firm up your connection with the ground.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
