Old 07-11-2015, 07:30 PM   #1
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Camco 44573 Yellow Tri-Leveler
I m looking for feedback from anyone who has tried these 3 level levelers.
Ken
http://www.amazon.com/Camco-44573-Ye.../dp/B000BUQOFO
Old 07-11-2015, 09:51 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
The reviewers on Amazon seem to like it.
Old 07-11-2015, 10:07 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Hi Ken, we have one that was for our VW Camper some years ago. I never felt there was quite enough room on any of the levels to allow the tire to fit completely onto it. It looked like the tire was about to roll off because so much of the tread was not supported. Never really used it for that reason, but we've still got it in the box of unused RV junk.
Now when I think about it I probably could have made a little backside chock from wood that would fit into the next level down and lock the tire in place. Thanks for reminding me about it. If it holds the tire securely it would also serve as a jack to remove a wheel on a tandem axle Airstream.
Its long flat bottom surface would be unlikely to sink into soft ground.
Doug and Cheryl
Old 07-11-2015, 10:23 PM   #4
Ag&Au's Avatar
Thanks Doug,
I had the same thought about the platform size.
I read one place that people use it on one wheel only of a tandem axle trailer. Not so sure that sounds like such a good idea to me.
Ken
Old 07-11-2015, 10:30 PM   #5
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
If you try to use 2 of them on a tandem axle they won't fit between the tires.
I have 2 of them if your interested.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 07-11-2015, 11:01 PM   #6
Ag&Au's Avatar
That's not a positive review.
What are you using in place of them?
Ken
Old 07-11-2015, 11:20 PM   #7
Glenritas's Avatar
1969 25' Tradewind
To heck with the hi tech stuff , simple 2x6's or 1x6x6 squares depending on what's need to get level.
Now if a couple of people with a single axle is interested , I have 2 new Yellow things.
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
Old 07-12-2015, 01:59 PM   #8
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
High tech is great, sometimes. I still like simple, and cheap, in most cases it works as good or better, and doesn't take up any more space...
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 07-12-2015, 02:10 PM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Don't fear progress or change.
I use a pair of the Andersen Levelers. From 0 to 4 inches. Not limited to three set heights.
MICHAEL
Old 07-12-2015, 05:11 PM   #10
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Google Anderson Leveler, a U-Tube video should come up. You can shorten one to fit between close tandems. They are smooth and the accompanying chock slips under the raised leading edge to cradle the tire. A bit spendy but well worth it IMHO.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 07-12-2015, 07:32 PM   #11
Ag&Au's Avatar
Thanks for the replies. I got the feedback I was expecting. I think I'll give the Andersons a try.
Ken
Old 07-13-2015, 09:23 PM   #12
2018 25' Flying Cloud
LAKE KIOWA , TX
I have a single axle 22 foot Airstream and in my opinion it has been the best accessory I have purchased for the trailer. Go for it.
cfishii is offline   Reply With Quote
Old 07-13-2015, 09:34 PM   #13
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I know what you mean. I get bummed when our site is level and I don't get to use them! 😄
Old 07-13-2015, 11:48 PM   #14
Ag&Au's Avatar
I am a bit concerned about using the Camco leveler on a dual axle trailer. Since apparently one won't fit between the wheels, you are left with using just one wheel for leveling, The other wheel will be unloaded to an unknown (at least to me) amount. The unloaded weight will be an additional weight on the wheel and axle on the leveler. I am concerned it could cause an overload on the tire and axle bearing the extra weight. Any comments?
Ken
Mounting Camco Olympian 5500 grill Bobsprinter Sprinter and B-van Forum 6 06-28-2015 09:09 PM
Camco RV Stove Top Cover White Universal Fit clicknathan Interior Restoration Forum 0 02-08-2013 05:24 PM
Is Camco 59003 / TPA ACR6 regulator adjustable? DKB_SATX LP Gas, Piping, Tanks & Regulators 0 09-03-2011 11:35 AM
Camco Camper Drain Trap? brattwurzt Plumbing - Systems & Fixtures 1 08-20-2011 11:17 AM
Camco Tornado Tank Rinsers beaubayou Waste Systems, Tanks & Totes 3 03-23-2008 01:53 PM
