Old 07-14-2015, 06:49 AM   #15
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Ag&Au View Post
I am a bit concerned about using the Camco leveler on a dual axle trailer. Since apparently one won't fit between the wheels, you are left with using just one wheel for leveling, The other wheel will be unloaded to an unknown (at least to me) amount. The unloaded weight will be an additional weight on the wheel and axle on the leveler. I am concerned it could cause an overload on the tire and axle bearing the extra weight. Any comments?
Ken
I would want to avoid unequal wheel loads. I realize folks may do this for less than a day, but I'd only want to do it for the time it takes to replace a failed tire with the spare.
FWIW, I use pressure treated wood planks for leveling. With a pickup it's easy enough to store in various sizes. I'd agree they're heavy and cumbersome. But until something else bridges the gap, I'll stay with them. (Same for plastic Legos for stabilizer pads. Gave away the last set).
Mounting Camco Olympian 5500 grill Bobsprinter Sprinter and B-van Forum 6 06-28-2015 10:09 PM
Camco RV Stove Top Cover White Universal Fit clicknathan Interior Restoration Forum 0 02-08-2013 06:24 PM
Is Camco 59003 / TPA ACR6 regulator adjustable? DKB_SATX LP Gas, Piping, Tanks & Regulators 0 09-03-2011 12:35 PM
Camco Camper Drain Trap? brattwurzt Plumbing - Systems & Fixtures 1 08-20-2011 12:17 PM
Camco Tornado Tank Rinsers beaubayou Waste Systems, Tanks & Totes 3 03-23-2008 02:53 PM
