Old 09-06-2016, 08:59 PM   #15
1979 23' Safari
Wayland , New York
Can't believe the truck jack broke from this! The tongue has got to be less than the truck weight, cheap!
Old 09-06-2016, 09:23 PM   #16
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I was surprised and shocked as well.
It's like they put the Jack in there just to say there's a jack in there, but don't intend for you to use it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-07-2016, 07:34 AM   #17
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
I just ordered my husky. Can't wait to get rid of my screeching Attwod
The Colonel is offline   Reply With Quote
Old 09-07-2016, 07:56 AM   #18
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Pretty sure the Husky will surprise you. Quiet, and the ball screw drive is what really caught my eye plus you can operate manually w/o removing head. But haven't even needed that yet.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-07-2016, 09:11 AM   #19
aftermath's Avatar
Spokane , Washington
Truck Jack?
I can't believe that Toyota would put a cheap jack in their truck. I have used mine to lift my truck, lift the Airstream to change a tire, lift a U-Haul trailer and even used it to pull a post out of the ground. Everything on my Tundra is sturdy, including the jack.
What upsets me more is that Airstream is putting a crummy jack on their new trailers. Unacceptable.
aftermath is offline   Reply With Quote
Old 09-07-2016, 11:12 AM   #20
m.hony's Avatar
2013 30' Classic
The jack in my 2007 Tundra is pretty bad.
To have the metal break out where the crank inserts is pretty bad.
Why would a jack be made of a brittle cast metal?
I just don't trust it.
TAC #MS-10
Airforums #70955
Old 09-08-2016, 07:29 AM   #21
2013 31' Classic
Sacramento , California
When I ordered the Husky 82022 I was concerned about the clearance between the jack head and the tank cover. When I removed the Baker jack I noticed Airstream had installed one star washer on the front hole which angled the jack head back slightly closer to the tank cover. So I installed two star washers on the back holes angling the Husky jack slightly forward. The clearance is good now. The Husky silver color goes great with the aluminum.
bretharte is offline   Reply With Quote
Old 09-08-2016, 07:54 AM   #22
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
It seems to me that the original tongue jack went belly up due to the OP trying to raise the trailer and truck off the ground to put boards under the rear tires of the truck. I don't believe tongue jacks are made for this kind of weight.
Steve, Christy, Anna and Scout (Border Collie deceased 11-30-2016)
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 09-08-2016, 08:17 AM   #23
m.hony's Avatar
2013 30' Classic
It wasn't the jack's fault I tried to lift more than 3,500# with no wheel chocks on place.
The weight of the trailer rolled back against it and bent the jack post.
I am paying $339 stupid tax on that one.
I ordered the same jack to keep the original like new appearance of my trailer.
I could have ordered a black Atwood I guess. That is what Airstream is using now.
TAC #MS-10
Airforums #70955
Old 09-18-2016, 04:26 PM   #24
m.hony's Avatar
2013 30' Classic
New jack installed.
Woohoo!
TAC #MS-10
Airforums #70955
Wanted: Barker (H & H) Super Jack Stem Dumpster Airstream Classifieds 0 07-03-2014 07:26 PM
Axis, now a division of Al-Ko Axles overlander63 Axles 5 09-23-2011 10:56 AM
Barker Super Jack Problem Luckyducks Jacks, Stabilizers, Lifting and Leveling 1 03-20-2011 09:49 AM
Barker H & H Super Jack Problem-HELP!!!! AirHog Jacks, Stabilizers, Lifting and Leveling 3 04-29-2004 08:43 PM
P.M. Division, need some STUPIDITY help tin can luv Our Community 2 03-23-2004 08:11 AM
