Old 12-11-2008, 11:20 PM   #1
bonita , California
Bolt size for new mechanical jack?
Just got a new jack for my '73 Sovereign. But it was missing the bolts. I purchased the trailer without a jack (or bolts) so I don't have the old bolts either. Anyone know the correct bolt size? Thanks! 1st post for me.
toddingalls is offline   Reply With Quote
Old 12-12-2008, 05:11 AM   #2
1973 31' Excella 500
Morristown , Tennessee
Just from memory and not actually standing at my trailer this early in the morning, I seem to recall that these bolts are standard 1/2 inch bolts about 1 inch long. If I were in this situation, I would fo to ACE hardware and get a sampling of different sizes with standard threads - stainless, of course. Try them and don't forget to lube the old threads. If you have a tap and die set, you could use the thread gauge to get the number of threads per inch and then retap the hoole to get the bolt size.
This would be easier if you could get the trailer to the store. Either way, this is one of the simpler problems to repair. Hopefully someone will pitch in and help. The repair manual for my '73 Excella only says remove the bolts and resuse to install a new jack - no picture or description.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Old 12-13-2008, 01:54 AM   #3
bonita , California
Thanks Joe! If I don't get an exact answer from someone I will just use your suggestion.
I realize now that the holes in the tongue are threaded. Do you know if I need to add a washer and nut to the end of the bolt? I would think so, but just trying to confirm since I've never seen the original setup.
Todd
P.S. I've posted some pics of my progress on the interior.
Old 12-13-2008, 05:27 AM   #4
SteveH's Avatar
Common Sense , Texas
If you are talking about the tongue jack, I believe they are 3/8" course thread.
Regards,
Steve
Old 12-14-2008, 01:43 PM   #5
bonita , California
Tongue Jack
Steve-
Yes I'm installing a tongue jack. Do you know if I need to add a washer and nut to the end of the bolts? I would think so, but just trying to confirm since I've never seen the original setup.
Todd
Old 12-14-2008, 02:34 PM   #6
SteveH's Avatar
My original setup uses 3/8" bolts thru the jack flange into the threaded holes in the hitch, with no nuts or washers on the under side.
I believe if I was reinstalling one today, I'd at a minimum put blue Locktite on those bolts.
Regards,
Steve
Need help with mechanical jack imeynstein Jacks, Stabilizers, Lifting and Leveling 4 11-09-2008 07:09 PM
lug bolt size airtim Axles 8 03-09-2005 09:55 PM
Power Jack Breaker Size Rick Alston Electrical - Systems, Generators, Batteries & Solar 4 08-31-2004 11:46 AM
Lug Bolt Size for '78 Sovereign dinoburb Wheels, Hubs & Bearings 2 03-20-2004 03:34 PM
Axle mounting bolt size? Bryanhu Axles 11 10-11-2003 08:20 PM
