Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
View Poll Results: What kind of levelers do you use?
lumber scraps 28 43.08%
plastic lego-like leveling blocks 32 49.23%
other - please explain 7 10.77%
none - I'm ok with a little lean 2 3.08%
Multiple Choice Poll. Voters: 65. You may not vote on this poll
Old 07-18-2009, 09:56 AM   #1
moderator
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
blocks, boards or legos - poll
I have been wondering how folks level their rigs. We travel with few 2 x 6 and 1x6 scraps of lumber for leveling but I've seen all kinds of stuff used at campgrounds to level.
We tried some of those lego-esque plastic leveling blocks but found that they scooted around when we tried to back over them and came away with big clods of dirt when it was time to pack them up - very messy.
I've seen some very cool aluminum cresecent shaped chocks that can be driven up on to level... anyone use those?
Last year I watched a lady drive her SOB up onto a bag of ice to level. It worked - for a while....
So what do you use to even up those less than perfect parking places?
77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door
AIR # 3181 | WBCCI # 5575
Bullies thrive where leadership fails
Janet is offline   Reply With Quote
Old 07-18-2009, 09:59 AM   #2
Liberator
klattu's Avatar
Profile:  Heart of Dixie , Alabama
Images: 841
Scrap treated lumber works for me.
But I don't spend all day getting it level, just as long as I don't roll out of bed is good enough
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator
klattu is offline   Reply With Quote
Old 07-18-2009, 10:01 AM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
We use the plastic leveling blocks. I just knock them together to get rid of the dirt. They're also handy to raise a tire off the ground to change a flat, and a lot easier to handle than a 2x6.
(No Longer at Inland RV)
Old 07-18-2009, 10:16 AM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Our legos haven't scooted excessively. They are convenient to store and usually clean enough to put right back into a roadside storage compartment. Like Terry says, stuff knocks off fairly easily if there's a decent pad under the trailer. That doesn't always happen on turf. The outside shower works to clean them off then and there, at our next campsite or at home.
Best legos I saw were orange ones cosmotini had. There even was a chock that meshed with the blocks.
Old 07-18-2009, 10:11 AM   #5
Wingeezer's Avatar
Profile:  2005 30' Classic
Burlington , Ontario
We bought two sets of the "Lego" blocks and I'm pleased with them.
I would have thought that smooth bits of wood would scoot around much more than the lego blocks as the latter do interlock & cannot shift on one another, and I would think the many sharp edges on the bottom layer should dig into the earth more than smooth wood.
They have worked fine for us so far in any case.
We haven't encountered them getting plugged with dirt, but I guess that might happen under muddy conditions - should be easy to rinse with a hose though, and non-absorbent.
I used them last to make a pyramid under one wheel on one axle in order to get the wheel on the other axle up in the air in order to remove and check wheel bearings - worked very well and better than messing with jacks.
With such a high pyramid of interlocking blocks, and with this being done on asphalt in front of our home, I really expected to have problems with the blocks sliding on the smooth asphalt as I tried to back onto the blocks - but they held firm.
I'm happy with them & would buy again!
Brian
PS I think I read another thread talking about those aluminium crescent shaped gadgets that I believe are intended to lift the wheel off the ground for wheel changing.
If we are talking the same thing, I'm not sure they would be good for leveling as I don't imagine you can stop with them part way up - not 100% sure, never used them.
Also I think some folks said they could damage the newer AS axles with rubber suspension and were really meant for older round axles with conventional leaf springs.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 07-18-2009, 10:20 AM   #6
Stefrobrts's Avatar
Profile:  1968 17' Caravel
. , Washington
Other - we use the BAL single axle leveler. Best accessory ever! You slide it under the tire on the low side after you're parked and use the provided ratcheting wrench to turn the big screw and it lifts the tire until you're happy with it.
The only problem is that if we're on uneven ground (and we often are) sometimes I have to slide a little piece of board under the tire as we park to lift it enough to slide the leveler under there. But it works great when parked on paved spots, and most dirt/grass campsites, and if we happen to get a level spot to start with we just use it as an extra chock.
BAL Light Trailer Tire Leveler - Item - Camping World
Stephanie
Old 07-18-2009, 11:01 AM   #7
Foiled Again's Avatar
Virginia Beach , Virginia
Camping World sells the yellow legos, but WalMart and many independent stores sell the orange ones. And I have seen that the yellow ones tend to pick up more dirt. The integrated chocks are handy too. Very sturdy. When I started out I bought the cheap yellow plastic chocks, and promptly forgot I had them and drove right over them while leaving the campground. They might have convincingly stopped a wheelbarrow, but a heavy trailer smashed them flat with NO hesitation that could be felt from the cab.
One thing you shouldn't use the legos for is to put down the front jack, it's too much pressure on a small area. (Or you just sacrifice one lego and use it until every inch of the surface has been maimed.)
Paula
Today is a gift. That's why they call it "the present"
Old 07-18-2009, 11:07 AM   #8
Certifiable
mistral blue's Avatar
Profile:  1977 Argosy 24
Beautiful , New England
2 sets of orange legos and some scrap wood in case I need it for the jack.
"IT'S A MAGICAL WORLD, HOBBES, OL' BUDDY... LET'S GO EXPLORING!" ~ CALVIN
mistral blue is offline   Reply With Quote
Old 07-18-2009, 11:20 AM   #9
memgrove2000's Avatar
Profile:  1972 31' Sovereign
Elkhart , Indiana
We have a set of Four cast aluminum triangles. There are two of each size, one small triangle about 5 inches at the base and 4 inches tall, the outer size is about 14 inches long and 4 or 5 inches tall. with interlocking ridges all over them. they can be used in many different ways. to level the trailer, change a tire or as a tire chock (or all of these at the same time). I thought that I had an old Wally store catalog here with a picture but I cant find it now. I will take a picture when we get over to the trailer next time. They are really cool!
Mike
Have a great day!
1972, 31 Foot Sov. Intl.
memgrove2000 is offline   Reply With Quote
Old 07-18-2009, 11:26 AM   #10
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
We use the Lynx levelers Tri Lynx Corporation Lynx Levelers. Find they are light weight, strong and work great on any surface we have tried them on. Also bought one of the Lynx chocks to use with the levelers. Lynx has the bonus of being made right here in the good old USA.
Royce (KORKK) and Karen
AIR# 3913
'77' Minuet 6 Metre TV: '94' Wrangler, 4.0L inline 6, Ford 8.8 rear, NV4500 tranny, Old Man Emu suspension, 30x9.5 tires
Royce is offline   Reply With Quote
Old 07-18-2009, 11:38 AM   #11
3 Dog Nite's Avatar
Profile:  1974 25' Tradewind
Cleveland , Tennessee
2 x 6 lumber with beveled ends are what I use. The beveled ends allow the tire to roll up easier. This is important when stacking like a pyramid for a higher lift. I use regular wood as the ramps will crack over time. The cracked wood then goes into the campfire. If you use pressure treated wood, you can't burn it when they crack.
I'm not sure if plastic legos would support my MH over time. They would be used almost daily as we fulltime. Don't want to put those in the fire either.
Ricky
I know the voices in my head aren't real, but some of them have pretty good ideas.
AIR 22749
1974 25' Tradewind - no TV yet
1989 345 LE Classic Motorhome
Courtesy Parking; 20 amp, water, dump, wifi
'tween exits 27 & 33, I-75
3 Dog Nite is offline   Reply With Quote
Old 07-18-2009, 01:16 PM   #12
Isadora's Avatar
Profile:  1976 Argosy 24
Joplin , Missouri
We use plastic leveling blocks and have never had a problem with scooting--but we back up, put the blocks down and then pull forward onto them. Seems to work really well. So far have not had a problem with dirt getting into them. I do wish they were some other color than bright orange, tho....maybe a nice dark green, or brown.
Jim and Sandy
"To know is nothing at all. To imagine, is everything." --Albert Einstein
Isadora is offline   Reply With Quote
Old 07-18-2009, 03:11 PM   #13
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
We actually have both. It depends on the circumstance. But I mostly use the lumber and although my tongue jack has a sand shoe I always carry a rough cut 2x8x3 that I set the tongue on, I have never had the jack sink yet. It also protects the asphalt under the tongue jack,if that's what we are parked on.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336
My your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 07-18-2009, 05:10 PM   #14
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
We're camping this weekend, and I forgot the 5/4 deck board scraps we use for this purpose. We were high on the curb side, and I had one board for two tires, I was sweating my tail off, and rather disgusted.
So I'm fiddle farting around when finally had a "Forest for the Trees" moment and used the single board to dig two holes to drop the curb side tires into.
Problem solved...No chocks required... and my reward was Beer.
We have the orange legos too, but never have used them.
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Is this a needed spacer for the floor boards? 2333 Repairing/Replacing Floor &/or Frame 4 Yesterday 08:07 PM
OK to use 3/4 Rustic Pine Boards? IronGiant Floor Finishes 2 05-10-2009 08:09 AM
What to use as leveling blocks flint Jacks, Stabilizers, Lifting and Leveling 33 03-27-2008 02:31 PM
Leveling Boards Length? LabWagGun Our Community 7 06-24-2003 08:57 AM
