Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 01-06-2009, 06:17 PM   #29
AirsDream's Avatar
Profile:  1999 23' Safari
Perrysburg , Ann Arbor
Bated Breath
Well, we're all waiting to hear what happens in the next exciting chapter! What is his daredevil plan? Will it work out? Will the venturers be marooned on Venus?
Do tell all!
AirsDream is offline   Reply With Quote
Old 01-06-2009, 07:21 PM   #30
GoMopar440's Avatar
Profile:  1973 31' Sovereign
Aransas Pass , Texas
Muahaaahaaahaaa!!!!
GoMopar440 is offline   Reply With Quote
Old 01-06-2009, 07:26 PM   #31
SafariSS's Avatar
Profile:  2005 30' Safari
Houston Texas , Texas
How did I know..
I shoulda' known he was from Texas! Down here they do dental work with a torch!
You know the saying, if you aint oil field you aint sh*t...!
SafariSS is offline   Reply With Quote
Old 01-06-2009, 07:40 PM   #32
AirsDream's Avatar
Dental work?
I dunno about that, but I've seen folks cook with oxy-acetylene! Not always a pretty sight!
I think he's tellin' us that he's plannin' to use the "blue tip wrench"!!!!! That, too may not be a pretty sight, but I betcha he gets the stabliziners off!
Old 01-06-2009, 08:00 PM   #33
GoMopar440's Avatar
I'm just here as a temporary Texan again. I was stationed here at NAVSTA Ingleside from '92 to '96 and now again from '07 to Sept '09 when I finally retire from the Navy after 20 years.
I'm a military brat so I'm from all over the country. My dad didn't retire from the Navy till after I was already at my first duty station. If I had to call anywhere "home" it would be Maine where most of my relatives are. Of course, I wasn't born there either so...
Old 01-07-2009, 04:56 PM   #34
GoMopar440's Avatar
Dang it! I didn't get to break out the torch.
I was able to put a bottle jack and a piece of 2x4 under the A frame and just slightly jack it up enough to get the front stabilizers to clear the paver stones. I pulled the stones out of the way and doused the long stabilizer screw with PB Blaster. When I tried to turn them, they actually came up! Enough to clear the ground for now anyway. I did the same for the rear stabilizers by putting the bottle jack and 2x4 just aft of teh big girder axle plate. The rear jacks also came up but since the bend in them is so severe, I only have about 6" ground clearance under the lowest point. Now I just need to unbolt them before trying to move the AS.
Sorry, no pics today. I forgot the camera at home.
Old 01-07-2009, 05:53 PM   #35
Profile:  2008 25' Safari FB SE
Crawford , Colorado
That was much too simple for all the advanced thinking that has gone on here. Couldn't you pretend that you had to use shaped charges?
Gene
CrawfordGene is offline   Reply With Quote
Old 01-07-2009, 06:24 PM   #36
GoMopar440's Avatar
How about C4?
Old 01-07-2009, 10:14 PM   #37
Profile:  1967 26' Overlander
Winston Salem , North Carolina
Images: 101
We still want pics
Greg
Winston Salem, NC
WBCCI 5218, Piedmont NC Unit 161
1967 Overlander International.
FTC 15771
1979 Avion 30ft rear bath
Silverwanabe is offline   Reply With Quote
Old 01-08-2009, 12:20 PM   #38
GoMopar440's Avatar
Good thing I didn't have to resort to this...
Old 01-08-2009, 01:49 PM   #39
AirsDream's Avatar
Aw, darn! We were hoping for something exciting ... if not the Sawzall, then the torch or a plasma cutter or maybe some sort of low-yield nuke.
Well, in all, it sounds as if you've got the solution well under way. Congrats.
Old 01-08-2009, 03:54 PM   #40
GoMopar440's Avatar
I don't have any pics of getting the stabilizers up since I didn't have the camera with me at the time. Today however, I had my wife and the camera with me. These pics should give you an idea of how low to the ground the trailer is sitting. I could only get under the trailer as far as my chest to unbolt the stabilizers. Half of the stabilizer mounting bolts snapped the heads right off.
In the second pic you can see how little ground clearance I had with the bent stabilizers all the way up.
And here's the aftermath...
Old 01-08-2009, 04:01 PM   #41
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Hopefully you can salvage the stabilizers, they are not cheap.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 01-08-2009, 04:19 PM   #42
GoMopar440's Avatar
I might be able to save one of them by swaping some parts around. Three of them have bent main beams and I'm not even going to try to straighten those out.
Stabilizers khadley Jacks, Stabilizers, Lifting and Leveling 1 11-06-2008 06:45 AM
Stabilizers or Scissors...? drag'nwagon Jacks, Stabilizers, Lifting and Leveling 34 07-17-2008 11:37 AM
Cleaned up my BAL stabilizers... Sneakinup Jacks, Stabilizers, Lifting and Leveling 0 04-27-2004 06:29 PM
A&E Stabilizers danesh Parts Archive 0 12-07-2003 11:47 PM
BAL Stabilizers kamadeca Jacks, Stabilizers, Lifting and Leveling 1 11-28-2003 01:32 PM
