Old 07-14-2015, 12:14 PM   #1
Norman , Oklahoma
Best way to level & stabilize a '60
Just picked up a 1960 24 footer. The previous owners just used 2 jack stands and the tongue jack. I'm thinking there should be a way to mount jacks (to frame, bumper, or such) so we don't have to haul and use jack stands which don't really work well anyway.
Please educate me. 😊
glw73069 is offline   Reply With Quote
Old 07-14-2015, 01:32 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I use jackstands, but I have considered getting a set of those BAL crank down type stabilizers and mounting them to the frame in the back. I know some folks have done that. Though the jackstands work fine for me. Sometimes I don't even use them.
Stephanie
Old 07-14-2015, 02:21 PM   #3
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I wouldn't trust the jack stands to level. You have to be careful where you place a jack when changing a tire due to the possibility of frame damage. Use leveling blocks instead - they're cheap, easy to use and quick. Then you can use the jack stands to stabilize the rig. Or you can by the stabilizers online and attach them to the frame (I think you can do this on a '60) - less hassle than the jack stands.
DryFly is offline   Reply With Quote
Old 07-14-2015, 02:38 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use two Andersen Levelers. I rarely use the attached stabilizers as I am solo and usually do not need them. Never try to use the the stabilizers to lift or level the trailer. They simply are not designed to do this.
MICHAEL
Old 07-15-2015, 01:23 PM   #5
BigButtUgly's Avatar
1958 22' Caravanner
not shared , Nebraska
I welded 2 scissors jacks to the rear frame but welded perpendicular, wheel on front crank down , and no chocks. Yes it rolled backwards destroying the scissors. So....no front wheel, use 4 chocks and weld scissor jacks parallel to the frame. I crank mine with 19.6 volt drill with liberal synthetic oil on threads.
BigButtUgly is offline   Reply With Quote
Best way to get 120V 30 AMP from a 5 KW generator Hummer Electrical - Systems, Generators, Batteries & Solar 8 10-31-2014 08:47 PM
Best RV Level Jobs tsunami On The Road... 18 07-26-2014 08:11 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
Pipe Frame stabilize/reinforcement Vintage One Repairing/Replacing Floor &/or Frame 1 07-05-2010 12:54 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
