Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 07-22-2017, 02:47 PM   #1
2017 23' International
Best place to order replacement stabilizer jacks for 23 FB?
Mine are 6 months old and the rear right got bent and I had to take it off. The numbers etched on are 855140 and 855141. I need to completely replace the old one. Click image for larger version
Name:	ImageUploadedByAirstream Forums1500756191.836074.jpg
The older I get , the better I was.
troubadour1 is offline   Reply With Quote
Old 07-22-2017, 03:24 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
If yours matches mine, then it is a Norco Industries, BAL "T" type stabilizer jack. Airstream uses number 4000093 or 400093-A for identification.
Prices vary widely, the best price currently:
http://odmrv.com/catalog/index.php?m...roducts_id=369
http://trvparts.com/catalog/index.ph...roducts_id=575
You might try calling PPL Motor Homes in Houston to see if they carry it. They price aggressively and turnaround is quick in my experience.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 07-22-2017, 06:42 PM   #3
Thanks. My main concern is the same screw in points I want to stay with the template from the factory. Camper clinic 2 in Budapest said they have mine in stock they think.
Old 08-23-2017, 11:55 AM   #4
2017 27' Flying Cloud
Box Elder , SD
I tried to take off from a site with the right front stabilizer still down. Bent the crap out of it. 2017 27FB. I called the AS dealer and they ordered a new one from AS which shipped directly to my house. Cost was about $100.00 which included the shipping.
When I went to replace, the inner single bolt was not tight to begin with and would not tighten up after installing the new stabilizer. So I've got to do something about that.
Larry
devilsbox is offline   Reply With Quote
Fuse replacement for stabilizer jacks rowdyATX Jacks, Stabilizers, Lifting and Leveling 4 05-11-2023 08:09 AM
potable and grey water tanks, best place to order them alexdubs Waste Systems, Tanks & Totes 0 11-30-2016 09:36 PM
Best Place to order foam these days? zoeb nj Upholstery, Blinds, Walls & Interior Finishes 1 06-18-2014 09:08 PM
best place to order trailer appliances... Neenm General Interior Topics 5 10-23-2013 01:47 PM
Best place to order Cyclo Accessories? mtjim Cleaning, Stripping & Polishing 3 05-27-2009 08:04 AM
