Old 11-02-2014, 04:39 AM   #15
Colorado Springs , Colorado
If the lug nut was mauled with a 12-point socket you may have made a case for a 6-point socket.
minke is offline   Reply With Quote
Old 11-02-2014, 05:06 AM   #16
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
6-point is the only way to go.
2012 Dodge Durango Hemi/AWD
Old 11-02-2014, 06:49 AM   #17
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Be sure to re-torque those lug nuts after about 10, 20, 50, and 100 miles. It's amazing how loose they can get if you don't.
We nearly lost a wheel last year, and that's not good on a single axle trailer.
Old 11-02-2014, 07:08 AM   #18
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Cannonball, did you mangle the lug nut OR the chrome shell atop the lug nut ??? The chrome shell is easily mangled and cause the wrench to spin. Happened to me so, been there done that. I now carry a small sharp chisel and a smaller socket. I can split and peel off the chrome shell and remove the lug with a smaller socket. These things will always happen in places and times where you don't want them.
To the original question the best jack is the one you carry but never have to use. I have a 6t bottle jack and it works great. Would do for my truck too if needed. In the case of my tongue jack failing it also works great to hitch/un-hitch. It's small and fits into a nice compact clean case for storage. Those of us with tandem axels have the option of pulling onto blocks also so go for what works best at the time.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is online now   Reply With Quote
Old 11-02-2014, 07:20 AM   #19
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
The chrome cap was what went first. Of course, I was at the storage place without my full toolbox, just the truck box. Ah well, lesson learned.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
Old 11-05-2014, 02:17 PM   #20
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
OK, the tire repair saga is over and done. However, in an effort to save other Forum members some of the grief I experienced, I am posting a list of what is now "on board" as my tire change kit:
1. 6 ton bottle jack;
2. Set of Lynx levelers (I used 3);
3. Two pieces of scrap wood, roughly the same dimensions as the Lynx levelers (used on top & bottom of levelers to provide flat surface);
4. Wheel chocks for opposite tire;
5. 19" Craftsman breaker bar, 1/2" drive;
6. Set of three Craftsman extensions, 1/2" drive;
7. 3/4", 6 point, deep set Craftsman socket, 1/2" drive;
8. Craftsman torque wrench, 1/2" drive;
9. Old school "T" lug wrench; worthless for most anything, but you can use it to spin the lugs down real fast prior to applying proper torque. Plus, it belonged to my father, and looks cool;
10. Tire gauge;
11. Air compressor to plug into 12v outlet in truck to air up spare (do this before mounting the spare on the Airstream, please!);
12. Small flask of good quality bourbon for post tire change celebration.
Old 11-05-2014, 02:24 PM   #21
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I'll help you with #12.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 11-05-2014, 02:36 PM   #22
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
You're on. I'll send the GPS coordinates for the flask.
Old 11-05-2014, 02:40 PM   #23
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
One Omission from my prior post:
I also now carry some spare lug nuts that I found at Advance Auto Parts, just in case I "screw the pooch" again and mangle the chrome caps. However, based on another Forum members recommendation, I have a complete set of McGard lug nuts arriving any day, and am going to change over to those.
Old 11-05-2014, 02:58 PM   #24
2006 19' Safari SE
Hayes , Virginia
Jack placement
I have the 2006 Bambi and only have "one" jack placement on the curb side, behind the wheel. Nothing on the street side. I found out the hard way that the street side jacking point is not located adjacent to the curb side.
mocus is offline   Reply With Quote
Old 11-06-2014, 08:33 AM   #25
GCinSC2's Avatar
I'll bring some Rebel Yell.
S/OS #001
Old 11-06-2014, 09:29 PM   #26
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
Name the spot.
Old 11-07-2014, 06:01 AM   #27
GCinSC2's Avatar
Well, it might be a bit of a drive but the next chance is this Saturday, my back yard campfire pit. We'll be burning some Oak and sipping a bit.
S/OS #001
Old 11-07-2014, 07:35 AM   #28
2007 19' Bambi
Yorktown , Virginia
I'll be swapping out new Sendel wheels and Michelin tires on our 2007 Bambi in the driveway this weekend. I am very interested to know how you figured out where the frame jack points are located. Are they listed in any of the owners manuals? Can you describe where I should be looking once i crawl under?
thanks,
randf is offline   Reply With Quote
Seeking Tire Advice for Single Axle (1964 Airstream 4000lbs) travelfables Tires 5 05-28-2014 05:40 PM
Jack placement for tire change ferrygj99 Tires 4 05-10-2013 08:15 PM
Axle on 1955 single axle models? glacierrunne Axles 7 02-12-2010 02:38 PM
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
